Garadget Support
2020-06-12: Garadget changed something in their login process resulting in some extra effort to get the App to make it compatible. I've gone down the MQTT path with Garadget though for local support and it works great. Check out @jrfarrar post on how to get it all setup:
I'm cross referencing a post I just put in the Garadget community. Their device handler and Connect app work in Hubitat with some minor modifications. I didn't host it in my github just in case they want to support it officially. I'll wait to hear back from them before doing anything like that, but the changes are pretty minimal and well documented in the post.
Just want people to be able to find it if they search this community.
Hello, I have this error:
startup failed: Script1.groovy: 323: unexpected token: x @ line 323, column 49. uestContentType: "application/x-www-form ^ 1 error on line null
Any help is appreciated. Thanks.
Here is the code: **edit:code is corrected:
 *  Garadget Connect
 *  Copyright 2016 Stuart Buchanan
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 * 12/12/2017 V1.5 fixed bug introduced in v1.4 on initialize function.
 * 12/12/2017 V1.4 debug logging changes. - btrenbeath
 * 21/04/2017 V1.3 added url encoding to username and password for when special characters are used, with thanks to pastygangster
 * 20/03/2017 V1.2 updated to refresh the garadget devices every 1 minute which is the minimum schedule allowed in ST
 * 13/02/2016 V1.1 added the correct call for API url for EU/US servers, left to do: cleanup child devices when removed from setup
 * 12/02/2016 V1.0 initial release, left to do: cleanup child devices when removed from setup
 import java.net.URLEncoder
 import java.text.DecimalFormat
 import groovy.json.JsonSlurper
 import groovy.json.JsonOutput
private apiUrl() 			{ "https://api.particle.io" }
private getVendorName() 	{ "Garadget" }
private getVendorTokenPath(){ "https://api.particle.io/oauth/token" }
private getVendorIcon()		{ "https://dl.dropboxusercontent.com/s/lkrub180btbltm8/garadget_128.png" }
private getClientId() 		{ settings.clientId }
private getClientSecret() 	{ settings.clientSecret }
private getServerUrl() 		{ if(!settings.serverUrl){return getApiServerUrl()} }
 // Automatically generated. Make future change here.
definition(
    name: "Garadget (Connect)",
    namespace: "fuzzysb",
    author: "Stuart Buchanan",
    description: "Garadget Integration",
    category: "SmartThings Labs",
	iconUrl:   "https://dl.dropboxusercontent.com/s/lkrub180btbltm8/garadget_128.png",
	iconX2Url: "https://dl.dropboxusercontent.com/s/w8tvaedewwq56kr/garadget_256.png",
	iconX3Url: "https://dl.dropboxusercontent.com/s/5hiec37e0y5py06/garadget_512.png",
    oauth: true,
    singleInstance: true
    appSetting "serverUrl"
preferences {
	page(name: "startPage", title: "Garadget Integration", content: "startPage", install: false)
	page(name: "Credentials", title: "Fetch OAuth2 Credentials", content: "authPage", install: false)
  page(name: "mainPage", title: "Garadget Integration", content: "mainPage")
  page(name: "completePage", title: "${getVendorName()} is now connected to SmartThings!", content: "completePage")
	page(name: "listDevices", title: "Garadget Devices", content: "listDevices", install: false)
  page(name: "badCredentials", title: "Invalid Credentials", content: "badAuthPage", install: false)
mappings {
	path("/receivedToken"){action: [POST: "receivedToken", GET: "receivedToken"]}
def startPage() {
    if (state.garadgetAccessToken) { return mainPage() }
    else { return authPage() }
def mainPage(){
	def result = [success:false]
	if (!state.garadgetAccessToken) {
    	createAccessToken()
       	log.debug "About to create Smarthings Garadget access token."
        getToken(garadgetUsername, garadgetPassword)
    if (state.garadgetAccessToken){
    	result.success = true
    if(result.success == true) {
           		return completePage()
	} else {
    			return badAuthPage()
def completePage(){
	def description = "Tap 'Next' to proceed"
			return dynamicPage(name: "completePage", title: "Credentials Accepted!", nextPage: listDevices , uninstall: true, install:false) {
				section { href url: buildRedirectUrl("receivedToken"), style:"embedded", required:false, title:"${getVendorName()} is now connected to SmartThings!", description:description }
def badAuthPage(){
	log.debug "In badAuthPage"
    log.error "login result false"
       		return dynamicPage(name: "badCredentials", title: "Garadget", install:false, uninstall:true, nextPage: Credentials) {
				section("") {
					paragraph "Please check your username and password"
def authPage() {
	log.debug "In authPage"
	if(canInstallLabs()) {
		def description = null
			log.debug "Prompting for Auth Details."
			description = "Tap to enter Credentials."
			return dynamicPage(name: "Credentials", title: "Authorize Connection", nextPage: mainPage, uninstall: false , install:false) {
			section("Generate Username and Password") {
				input "garadgetUsername", "text", title: "Your Garadget Username", required: true
				input "garadgetPassword", "password", title: "Your Garadget Password", required: true
	else
		def upgradeNeeded = """To use SmartThings Labs, your Hub should be completely up to date.
To update your Hub, access Location Settings in the Main Menu (tap the gear next to your location name), select your Hub, and choose "Update Hub"."""
		return dynamicPage(name:"Credentials", title:"Upgrade needed!", nextPage:"", install:false, uninstall: true) {
			section {
				paragraph "$upgradeNeeded"
def createChildDevice(deviceFile, dni, name, label) {
	log.debug "In createChildDevice"
    try{
		def childDevice = addChildDevice("fuzzysb", deviceFile, dni, null, [name: name, label: label, completedSetup: true])
	} catch (e) {
		log.error "Error creating device: ${e}"
def listDevices() {
	log.debug "In listDevices"
	def options = getDeviceList()
	dynamicPage(name: "listDevices", title: "Choose devices", install: true) {
		section("Devices") {
			input "devices", "enum", title: "Select Device(s)", required: false, multiple: true, options: options, submitOnChange: true
def buildRedirectUrl(endPoint) {
	log.debug "In buildRedirectUrl"
	log.debug("returning: " + getServerUrl() + "/api/token/${state.accessToken}/smartapps/installations/${app.id}/${endPoint}")
	return "${getApiServerUrl()}/${hubUID}/apps/${app.id}/${endPoint}?access_token=${state.accessToken}"
def receivedToken() {
	log.debug "In receivedToken"
	def html = """
        <!DOCTYPE html>
        <html>
        <head>
        <meta name="viewport" content="width=device-width, initial-scale=1">
        <title>${getVendorName()} Connection</title>
        <style type="text/css">
            * { box-sizing: border-box; }
            @font-face {
                font-family: 'Swiss 721 W01 Thin';
                src: url('https://s3.amazonaws.com/smartapp-icons/Partner/fonts/swiss-721-thin-webfont.eot');
                src: url('https://s3.amazonaws.com/smartapp-icons/Partner/fonts/swiss-721-thin-webfont.eot?#iefix') format('embedded-opentype'),
                     url('https://s3.amazonaws.com/smartapp-icons/Partner/fonts/swiss-721-thin-webfont.woff') format('woff'),
                     url('https://s3.amazonaws.com/smartapp-icons/Partner/fonts/swiss-721-thin-webfont.ttf') format('truetype'),
                     url('https://s3.amazonaws.com/smartapp-icons/Partner/fonts/swiss-721-thin-webfont.svg#swis721_th_btthin') format('svg');
                font-weight: normal;
                font-style: normal;
            @font-face {
                font-family: 'Swiss 721 W01 Light';
                src: url('https://s3.amazonaws.com/smartapp-icons/Partner/fonts/swiss-721-light-webfont.eot');
                src: url('https://s3.amazonaws.com/smartapp-icons/Partner/fonts/swiss-721-light-webfont.eot?#iefix') format('embedded-opentype'),
                     url('https://s3.amazonaws.com/smartapp-icons/Partner/fonts/swiss-721-light-webfont.woff') format('woff'),
                     url('https://s3.amazonaws.com/smartapp-icons/Partner/fonts/swiss-721-light-webfont.ttf') format('truetype'),
                     url('https://s3.amazonaws.com/smartapp-icons/Partner/fonts/swiss-721-light-webfont.svg#swis721_lt_btlight') format('svg');
                font-style: normal;
            .container {
                width: 560px;
                padding: 40px;
                /*background: #eee;*/
                text-align: center;
            img {
                vertical-align: middle;
            img:nth-child(2) {
                margin: 0 30px;
            p {
                font-size: 2.2em;
                text-align: center;
                color: #666666;
                margin-bottom: 0;
            p:last-child {
                margin-top: 0px;
            span {
        </style>
        </head>
        <body>
            <div class="container">
                <img src=""" + getVendorIcon() + """ alt="Vendor icon" />
                <img src="https://s3.amazonaws.com/smartapp-icons/Partner/support/connected-device-icn%402x.png" alt="connected device icon" />
                <img src="https://s3.amazonaws.com/smartapp-icons/Partner/support/st-logo%402x.png" alt="SmartThings logo" />
                <p>Tap 'Done' to continue to Devices.</p>
			</div>
        </body>
        </html>
	render contentType: 'text/html', data: html
def getDeviceList() {
	def garadgetDevices = []
    httpGet(uri: "${apiUrl()}/v1/devices?access_token=${state.garadgetAccessToken}"){ resp ->
    	def restDevices = resp.data
		restDevices.each { garadget ->
        	if (garadget.connected == true)
                garadgetDevices << ["${garadget.id}|${garadget.name}":"${garadget.name}"]
	return garadgetDevices.sort()
def installed() {
	log.debug "Installed with settings: ${settings}"
	initialize()
def updated() {
	log.debug "Updated with settings: ${settings}"
	unsubscribe()
	unschedule()
	initialize()
def uninstalled() {
  log.debug "Uninstalling Garadget (Connect)"
  deleteToken()
  removeChildDevices(getChildDevices())
  log.debug "Garadget (Connect) Uninstalled"
def initialize() {
	log.debug "Initialized with settings: ${settings}"
	// Pull the latest device info into state
	getDeviceList();
    def children = getChildDevices()
    if(settings.devices) {
    	settings.devices.each { device ->
    	def item = device.tokenize('|')
        def deviceId = item[0]
        def deviceName = item[1]
        def existingDevices = children.find{ d -> d.deviceNetworkId.contains(deviceId) }
    		if(!existingDevices) {
				try {
					createChildDevice("Garadget", deviceId + ":" + state.garadgetAccessToken, "${deviceName}", deviceName)
				} catch (Exception e) {
	// Do the initial poll
	poll()
	// Schedule it to run every 1 minutes
	schedule("0 */1 * * * ?", "poll")
def getToken(garadgetUsername, garadgetPassword){
	log.debug "Executing 'sendCommand.setState'"
    def encodedUsername = URLEncoder.encode(garadgetUsername, "UTF-8")
 	def encodedPassword = URLEncoder.encode(garadgetPassword, "UTF-8")
    def body = ("grant_type=password&username=${encodedUsername}&password=${encodedPassword}&expires_in=0")
	sendCommand("createToken","particle","particle", body)
private sendCommand(method, user, pass, command) {
    def userpassascii = "${user}:${pass}"
	def userpass = "Basic " + userpassascii.bytes.encodeBase64().toString()
    def headers = [:]
    headers.put("Authorization", userpass)
	def methods = [
			'createToken': [
        				uri: getVendorTokenPath(),
            			requestContentType: "application/x-www-form-urlencoded",
                        headers: headers,
                	    body: command
            'deleteToken': [
        				uri: apiUrl() + "/v1/access_tokens/${state.garadgetAccessToken}",
                        headers: headers,
	def request = methods.getAt(method)
	log.debug "Http Params ("+request+")"
    try{
        if (method == "createToken"){
        	log.debug "Executing createToken 'sendCommand'"
            httpPost(request) { resp ->
                parseResponse(resp)
        }else if (method == "deleteToken"){
        	log.debug "Executing deleteToken 'sendCommand'"
            httpDelete(request) { resp ->
                parseResponse(resp)
        }else{
        log.debug "Executing default HttpGet 'sendCommand'"
            httpGet(request) { resp ->
                parseResponse(resp)
    } catch(Exception e){
        log.debug("___exception: " + e)
private parseResponse(resp) {
    log.debug("Executing parseResponse: "+resp.data)
    log.debug("Output status: "+resp.status)
    if(resp.status == 200) {
    	log.debug("Executing parseResponse.successTrue")
        state.garadgetAccessToken = resp.data.access_token
        log.debug("Access Token: "+ state.garadgetAccessToken)
		state.garadgetRefreshToken = resp.data.refresh_token
        log.debug("Refresh Token: "+ state.garadgetRefreshToken)
		state.garadgetTokenExpires = resp.data.expires_in
        log.debug("Token Expires: "+ state.garadgetTokenExpires)
        log.debug "Created new Garadget token"
    }else if(resp.status == 201){
        log.debug("Something was created/updated")
def poll() {
	log.debug "Executing - Service Manager - poll() - "
	getDeviceList();
	getAllChildDevices().each {
        it.statusCommand()
private Boolean canInstallLabs() {
	return hasAllHubsOver("000.011.00603")
private List getRealHubFirmwareVersions() {
	return location.hubs*.firmwareVersionString.findAll { it }
private Boolean hasAllHubsOver(String desiredFirmware) {
	return realHubFirmwareVersions.every { fw -> fw >= desiredFirmware }
void deleteToken() {
try{
    sendCommand("deleteToken","${garadgetUsername}","${garadgetPassword}",[])
	log.debug "Deleted the existing Garadget Access Token"
 } catch (e) {log.debug "Couldn't delete Garadget Token, There was an error (${e}), moving on"}
private removeChildDevices(delete) {
	try {
    	delete.each {
        	deleteChildDevice(it.deviceNetworkId)
            log.info "Successfully Removed Child Device: ${it.displayName} (${it.deviceNetworkId})"
    catch (e) { log.error "There was an error (${e}) when trying to delete the child device" }
The problem is the last line in the initialize() method. Did you copy this code from somewhere? the double quotes are some weird character instead. if you delete the double quotes on that line and type them in again it should get rid of that error.
Bad:
schedule(“0 */1 * * * ?”, “poll”)
Good:
Awesome, it worked now, but when I put my user name and password I get this:
then:
after I click done it goes back to picture 1. No app under apps.
Thank you for your help.
Ok, got it working, I used the code in my first post here, I used the driver unmodified for ST here, the last problem was because I did not OAuth the app, or at least that helped. Thank you!!!!
I used your examples, DH and the app. Am I correct that I need to look at changing the code, since I don't use Garadget, I don't need it to log into a account that I don't use. I jst need to be able to use my relays and photon.
I didn't create the app but just modified it to work on the Hubitat platform. I actually know very little about photon.
Not sure how to fix this -
" app:1932019-05-07 12:33:08.450 pm errorjava.lang.RuntimeException: OAuth is not enabled for this App on line 76 (mainPage)"
You need to enable oauth for the app:
Thank you so much. I knew it was an easy toggle and it works!
Any of you do something specific for your dashboard tile to control opening/closing and show it as opened closed for the virtual device that uses this device driver code?
adding this here as it seems the best place. I've tweaked these a bit so use at your own risk. I modified to use asynchttpGet instead of httpGet for the frequent calls to the host. It's new...and mostly untested but working on my setup with 3 doors currently.
Device Handler:
App:
Hi jrfarrar,
Thanks for posting new DH and App. I installed the App (V2.0) and DH (V1.6) but when I ran the app, it authenticated my credentials fine, so I hit next, and in the drop down where I should be able to choose my devices there are no devices listed. There should be 2 garage's doors listed there. Any ideas?
Maybe check the logs to see if there are any errors?
did you get any errors?
Did you oauth the app when it was installed?
New hubitat user (day0), first time garadget setup (I think that is relevant to the issue).
I had exactly the issue that @zachdrewry described. clean auth, no garage doors listed, nothing suspicious logged. I think there is a race condition on the asynchttpGet in listDevices, which causes the initialize code to not have any devices to select. Once the devices are found and cached, I suspect things work OK (I haven't backed out my workaround to verify that).
My workaround was to revert the (app) getDeviceList() method to the getDeviceList() method from the smartthings codebase. with that change (httpGet instead of asynchttpGet), the devices appear and have good data in them.
Thank you @cwitte , I was having the same issue with no devices showing, changing the app code as described worked perfectly..
@cwitte @gtnmtn @zachdrewry Sorry...I wasn't apparently tracking this thread. I updated the code to only use the async method during polling, not initial setup. Hopefully that will fix the issues.
Hey guys, new to this forum. I have an issue where when I try and enter my credentials, I am told to check my username or password within hubitat.
WHat can I do.It defitely is the write credentials
