Fortrezz WWA-01AA drive for C-8 hub
All,
I just came over from smartthings yesterday and this is my first post.
I was able to get all of my devices to come over but I am having trouble with the user defined driver for a Fortrezz WWA-01AA water sensor.
I have the sensor added to the hub. I am using the driver found here:
I changed all the instances of “physicalgraph” to “hubitat” in order to port this driver from smartthings to hubitat.
I am getting the following error in the log:
2023-03-19 12:14:51.598 AMerrororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: user_driver_philh30_FortrezZ_WWA_01AA_597.ping() is applicable for argument types: () values: []
The battery level seems to be coming over but nothing else. The device shows as a question mark in the dashboard. I am curious if anyone else is running with this sensor and would be able to share Hubitat driver for it that is working.
Thanks in advance.
There are several adjustments that need to be made to that code to port it over. Nothing major, but it won’t work until then…
Some users have said that the WaterCop driver works though.
I checked out the watercop and it does seem to be the same valve. My valve driver is stock and it seems to be working fine. I am having an issue with the fortrezz zwave sensors and the info I found on the watercop doesn't seem to relate to sensor drivers. Do you have a link you can share?
You mentioned some more changes need to be made to convert this smarrthings driver. Could you elaborate so I can dig in?
This should be close:
Driver Code
 *  Device Handler for Fortrezz WWA-01AA Temperature and Leak Sensor
 *  Copyright 2015 SmartThings
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 *  Based on the Smartsense Moisture device handler.
 *  TEMPERATURE
 *	The WWA-01AA provides a temperature report only if it is requested during its wakeup. Configure the wakeup interval
 *  based on the frequency that you want a temperature update (shorter intervals may shorten battery life).
 *  BATTERY
 *  The WWA-01AA reports battery only at either 99% or 0%, and will therefore battery will appear to die suddenly.
 *  ALARMS
 *	The water alarm sends a BasicSet.
 *  The freeze alarm is triggered at 39F, sending a SensorBinaryReport. This set point cannot be configured in the device.
 *  The overheating and freezing thresholds that are in the DH configuration do not get passed to the device, and therefore
 *  will not trigger an instant report from the device when the temperature breaks the threshold. Those thresholds will only
 *  trigger an event when the temperature is reported during the wake up.
metadata {
	definition (name: "FortrezZ WWA-01AA", namespace: "philh30", author: "philh30", runLocally: false, minHubCoreVersion: '000.017.0012', executeCommandsLocally: true, mnmn: "SmartThings", vid: "generic-leak") {
		capability "Water Sensor"
		capability "Sensor"
		capability "Battery"
		capability "Temperature Measurement"
		capability "Health Check"
		attribute "temperatureState", "string"
		fingerprint mfr:"0084", prod:"0053", model:"0216", deviceJoinName: "FortrezZ Temperature and Leak Sensor"
    preferences {
        input "wakeUpIntervalMinutes", "number", title: "Wake up interval in minutes (1-480). The WWA-01AA only reports temperature and battery status if they are requested during wakeup.", range: "1..480", required: true
        input "requestTemp", "enum", title: "Request temperature when device wakes up?", required: true,
        	options:[[0:"On"],
            		[1:"Off"]]
		input "logTemp", "enum", title: "Temperature reporting", required: true,
        	options:[[0:"Log changes only"],
            		[1:"Log every wake up"]]
        input "highTempThreshold", "number", title: "Overheating Threshold", range: "0..150", required: true
        input "lowTempThreshold", "number", title: "Freezing Threshold", range: "0..150", required: true
        input "requestBattery", "enum", title: "Request battery status when device wakes up?", required: true,
			options:[[0:"Every wake up"],
					[1:"Daily"],
					[2:"Weekly"],
					[3:"Never"]]
		input "logBattery", "enum", title: "Battery reporting", required: true,
	simulator {
		status "dry": "command: 2001, payload: 00"
		status "wet": "command: 2001, payload: FF"
		status "freezing": "command: 3003, payload: FF"
		status "normal": "command: 3003, payload: 00"
		for (int i = 0; i <= 100; i += 20) {
			status "battery ${i}%": new hubitat.zwave.Zwave().batteryV1.batteryReport(batteryLevel: i).incomingMessage()
	tiles(scale: 2) {
		multiAttributeTile(name:"water", type: "generic", width: 6, height: 4){
			tileAttribute ("device.water", key: "PRIMARY_CONTROL") {
				attributeState "dry", label: "Dry", icon:"st.alarm.water.dry", backgroundColor:"#ffffff"
				attributeState "wet", label: "Wet", icon:"st.alarm.water.wet", backgroundColor:"#00A0DC"
		standardTile("temperatureState", "device.temperatureState", width: 2, height: 2) {
			state "normal", icon:"st.alarm.temperature.normal", backgroundColor:"#ffffff"
            state "freezing", icon:"st.alarm.temperature.freeze", backgroundColor:"#00A0DC"
			state "overheated", icon:"st.alarm.temperature.overheat", backgroundColor:"#e86d13"
		valueTile("temperature", "device.temperature", width: 2, height: 2) {
			state("temperature", label:'${currentValue}°',
				backgroundColors:[
					[value: 31, color: "#153591"],
					[value: 44, color: "#1e9cbb"],
					[value: 59, color: "#90d2a7"],
					[value: 74, color: "#44b621"],
					[value: 84, color: "#f1d801"],
					[value: 95, color: "#d04e00"],
					[value: 96, color: "#bc2323"]
		valueTile("battery", "device.battery", decoration: "flat", inactiveLabel: false, width: 2, height: 2) {
			state "battery", label:'${currentValue}% battery', unit:""
		main (["water"])//, "temperatureState"])
		details(["water", "temperatureState", "temperature", "battery"])
	def result = []
	def parsedZwEvent = zwave.parse(description, [0x30: 1, 0x31: 1, 0x71: 1, 0x84: 1])
    log.debug "New event to parse: ${description}"
	if(parsedZwEvent) {
		if(parsedZwEvent.CMD == "8407") {
			//log.debug "Requesting battery report"
			if(!state.lastBatteryCheck) {
                result << new hubitat.device.HubAction(zwave.batteryV1.batteryGet().format())
            def ageInMinutes = state.lastBatteryCheck ? (new Date().time - state.lastBatteryCheck)/60000 : 600
            log.debug "Last Battery check was ${ageInMinutes/60/24} days ago"
            switch(requestBattery) {
            	case "0":
                	//Request battery status every time... Half minute lag to prevent repeat requests if multiple wake up notifications are received
                    if(ageInMinutes >= 0.5) {
                    break
                case "1":
                	//Request battery status daily
                	if(ageInMinutes >= 60*24) {
                    break
                case "2":
                	//Request battery status weekly
                    if(ageInMinutes >= 60*24*7) {
                	break
               	case "3":
                	//Request battery status never
                	break
            //log.debug "Requesting temperature report"
            if (requestTemp == "0") {
				def ageInSeconds = state.lastTemperature ? (new Date().time - state.lastTemperature)/1000 : 600
                state.lastTemperature = new Date().time
                if (ageInSeconds > 30) {
                	result << new hubitat.device.HubAction(zwave.sensorMultilevelV1.sensorMultilevelGet().format())
            //log.debug "Checking for config changes - update wakeup interval"
            if (state.updateConfigNextWakeup == 1) {
            	result << new hubitat.device.HubAction(zwave.wakeUpV1.wakeUpIntervalSet(seconds:60*wakeUpIntervalMinutes, nodeid:zwaveHubNodeId).format())
            	state.updateConfigNextWakeup = 0
            //log.debug "Requesting wakeup interval report"
            //result << new physical graph.device.HubAction(zwave.wakeUpV1.wakeUpIntervalGet().format())
            result << new hubitat.device.HubAction(zwave.wakeUpV1.wakeUpNoMoreInformation().format())
        result << createEvent( zwaveEvent(parsedZwEvent) )
	if(!result) result = [ descriptionText: parsedZwEvent, displayed: false ]
	log.debug "Parse returned ${result}"
    return result
def installed() {
    state.updateConfigNextWakeup = 1
def updated() {
def zwaveEvent(hubitat.zwave.commands.wakeupv1.WakeUpNotification cmd)
	[descriptionText: "${device.displayName} woke up", isStateChange: false]
def zwaveEvent(hubitat.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd)
    //This is the freeze event
    def map = [:]
	switch (cmd.CMD) {
    	case "2001":
    		map.name = "water"
			if(cmd.sensorValue == 0) {
            	map.value = "dry"
    			else { map.value = "wet" }
			map.descriptionText = "${device.displayName} is ${map.value}"
			break
        case "3003":
    		map.name = "temperatureState"
			if(cmd.sensorValue == 0) { map.value = "normal" }
    			else { map.value = "freezing" }
			break
        default:
        	log.debug "Unrecognized alarm"
    map
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
	def map = [:]
    if(cmd.batteryLevel == 0xFF) {
		map.name = "battery"
		map.value = 1
		map.descriptionText = "${device.displayName} has a low battery"
		map.displayed = true
	} else {
		map.value = 1 + cmd.batteryLevel > 0 ? cmd.batteryLevel.toString() : 1
		map.unit = "%"
    if (logBattery == "1") {
        map.isStateChange = true
    state.lastBatteryCheck = new Date().time
	map
def zwaveEvent(hubitat.zwave.commands.sensormultilevelv1.SensorMultilevelReport cmd)
    def map = [:]
	if(cmd.sensorType == 1) {
		map.name = "temperature"
		if(cmd.scale == 0) {
			map.value = getTemperature(cmd.scaledSensorValue)
		} else {
				map.value = cmd.scaledSensorValue
		map.unit = location.temperatureScale
        if (logTemp == "1") {
    if(map.value >= highTempThreshold) {
    	sendEvent(name: "temperatureState", value:"overheated", descriptionText: "${device.displayName} is overheated")
    } else if(map.value <= lowTempThreshold) {
    	sendEvent(name: "temperatureState", value:"freezing", descriptionText: "${device.displayName} is freezing")
    } else {
    	sendEvent(name: "temperatureState", value:"normal", descriptionText: "${device.displayName} is normal")
	map
def zwaveEvent(hubitat.zwave.commands.wakeupv1.WakeUpIntervalReport cmd)
	def map = [:]
    map.name = "wakeup"
    map.value = cmd.seconds / 60
    map.descriptionText = "${device.displayName} wake up interval is ${cmd.seconds / 60} minutes."
    map
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd)
    //This is the water event
    def map = [:]
    switch (cmd.CMD) {
    	case "2001":
    		map.name = "water"
			if(cmd.value == 0) {
            	map.value = "dry"
			break
        case "3003":
			if(cmd.value == 0) { map.value = "normal" }
			break
        default:
	map
def getTemperature(value) {
	if(location.temperatureScale == "C"){
		return value
	} else {
		return Math.round(celsiusToFahrenheit(value))
def zwaveEvent(hubitat.zwave.Command cmd)
	log.debug "COMMAND CLASS: $cmd"
def ping(){ }
I appreciate the post. Would you mind summarizing what you had to change from the original code posted above?
again, thanks.
There’s a longer post (App and driver porting to Hubitat) with everything to look for, but for this one
  • commented out the tiles and simulator sections- not used by Hubitat
  • created an attribute for temperaturestate as it was only defined in the tiles section
  • changed every occurance of physicalgraph to hubitat
The driver seems to be working for the WWA02 version of the sensor but the WWA01 version gets the following errors:
2023-03-20 08:17:33.324 PMwarnUnable to execute hubAction:8408 sent from Kitchen Sink Leak Sensor, invalid or unspecified protocol.
sys:12023-03-20 08:17:33.320 PMwarnUnable to execute hubAction:3104 sent from Kitchen Sink Leak Sensor, invalid or unspecified protocol.
sys:12023-03-20 08:17:33.316 PMwarnUnable to execute hubAction:8002 sent from Kitchen Sink Leak Sensor, invalid or unspecified protocol.
