Im using the relay switch to control a garage door, and using the input terminal with a magnetic reed switch to detect state.
C5 Hub - fw 2.3.5.125.
I have tried both the official driver and the user driver here - Mimolite garage door device driver - #70 by mbaran
Both exhibited the same issue, though initially it look like the user driver worked a bit better.
When given the close command, the relay fires and door starts to close but about 2 seconds in the door then opens, like it was also given an open command. There is no obstruction, I have the jumper removed on the mimolite so it should act as a momentary relay. And the thing just gets stuck in an open and close loop after that until I give it the open command.
