Hi, I can see from the past this device has had issues and they were fixed by @mike.maxwell but it seems to be the same again. I have a setup due to the zip gateway that it forces them to join with S0 and there are no longer any event from the device. Can it be looked at again to check please?
I assume this is on a C-7/C-8/C-8 Pro?
If so, here are a couple suggestions:
- Install ZWaveJS, pair the Mimo2 with no security and then switch back to zipgateway.
- Pair it using a secondary controller. I use an Aeon Labs Minimote.
Iām also tagging @bcopeland
I had the same thought but the C-7 are no longer able to move to zwaveJS it seems.
not possible in this case as its not me doing it
I think the URLs disclosed during the beta test of ZWaveJS will still work on the C-7.
No that's what I'm saying they don't anymore.
@bcopeland and way this could be sorted please?
