I have no way to test this, but a quick port of the ST DTH may give you something to start with:
Fortezz Flow Meter Device Driver
* FortrezZ Flow Meter Interface
* Copyright 2016 FortrezZ, LLC
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
********** Ported from the ST DTH ******************
metadata {
definition (name: "FortrezZ Flow Meter Interface", namespace: "fortrezz", author: "Daniel Kurin") {
capability "Battery"
capability "Energy Meter"
capability "Image Capture"
capability "Temperature Measurement"
capability "Sensor"
capability "Water Sensor"
attribute "gpm", "number"
attribute "cumulative", "number"
attribute "alarmState", "string"
attribute "chartMode", "string"
attribute "lastThreshhold", "number"
command "chartMode"
command "zero"
command "setHighFlowLevel", ["number"]
fingerprint deviceId: "0x2101", inClusters: "0x5E, 0x86, 0x72, 0x5A, 0x73, 0x71, 0x85, 0x59, 0x32, 0x31, 0x70, 0x80, 0x7A"
preferences {
input ("version", "text", title: "Plugin Version 1.5", description:"", required: false, displayDuringSetup: true)
input "gallonThreshhold", "decimal", title: "High Flow Rate Threshhold", description: "Flow rate (in gpm) that will trigger a notification.", defaultValue: 5, required: false, displayDuringSetup: true
// parse events into attributes
def results = []
if (description.startsWith("Err")) {
results << createEvent(descriptionText:description, displayed:true)
} else {
def cmd = zwave.parse(description, [ 0x80: 1, 0x84: 1, 0x71: 2, 0x72: 1 ])
if (cmd) {
results << createEvent( zwaveEvent(cmd) )
//log.debug "\"$description\" parsed to ${results.inspect()}"
if(gallonThreshhold != device.currentValue("lastThreshhold"))
results << setThreshhold(gallonThreshhold)
log.debug "zwave parsed to ${results.inspect()}"
return results
def updated()
log.debug("Updated")
def setHighFlowLevel(level)
setThreshhold(level)
def take() {
def mode = device.currentValue("chartMode")
if(mode == "day")
take1()
else if(mode == "week")
take7()
else if(mode == "month")
take28()
def chartMode(string) {
log.debug("ChartMode")
def state = device.currentValue("chartMode")
def tempValue = ""
switch(state)
case "day":
tempValue = "week"
break
case "week":
tempValue = "month"
break
case "month":
tempValue = "day"
break
default:
tempValue = "day"
break
sendEvent(name: "chartMode", value: tempValue)
take()
def take1() {
api("24hrs", "") {
log.debug("Image captured")
if(it.headers.'Content-Type'.contains("image/png")) {
if(it.data) {
storeImage(getPictureName("24hrs"), it.data)
def take7() {
api("7days", "") {
if(it.data) {
storeImage(getPictureName("7days"), it.data)
def take28() {
api("4weeks", "") {
if(it.data) {
storeImage(getPictureName("4weeks"), it.data)
def zero()
delayBetween([
zwave.meterV3.meterReset().format(),
zwave.meterV3.meterGet().format(),
zwave.firmwareUpdateMdV2.firmwareMdGet().format(),
], 100)
def zwaveEvent(hubitat.zwave.commands.sensormultilevelv5.SensorMultilevelReport cmd)
log.debug cmd
def map = [:]
if(cmd.sensorType == 1) {
map = [name: "temperature"]
if(cmd.scale == 0) {
map.value = getTemperature(cmd.scaledSensorValue)
} else {
map.value = cmd.scaledSensorValue
map.unit = location.temperatureScale
} /* else if(cmd.sensorType == 2) {
map = [name: "waterState"]
if(cmd.sensorValue[0] == 0x80) {
map.value = "flow"
sendEvent(name: "water", value: "dry")
} else if(cmd.sensorValue[0] == 0x00) {
map.value = "none"
} else if(cmd.sensorValue[0] == 0xFF) {
map.value = "overflow"
sendEvent(name: "water", value: "wet")
sendAlarm("waterOverflow")
return map
def zwaveEvent(hubitat.zwave.commands.meterv3.MeterReport cmd)
def map = [:]
map.name = "gpm"
def delta = cmd.scaledMeterValue - cmd.scaledPreviousMeterValue
if (delta < 0 || delta > 10000) {
log.error(cmd)
delta = 0
map.value = delta
map.unit = "gpm"
sendDataToCloud(delta)
sendEvent(name: "cumulative", value: cmd.scaledMeterValue, displayed: false, unit: "gal")
return map
def zwaveEvent(hubitat.zwave.commands.alarmv2.AlarmReport cmd)
def map = [:]
if (cmd.zwaveAlarmType == 8) // Power Alarm
map.name = "powerState" // For Tile (shows in "Recently")
if (cmd.zwaveAlarmEvent == 2) // AC Mains Disconnected
map.value = "disconnected"
sendAlarm("acMainsDisconnected")
else if (cmd.zwaveAlarmEvent == 3) // AC Mains Reconnected
map.value = "reconnected"
sendAlarm("acMainsReconnected")
else if (cmd.zwaveAlarmEvent == 0x0B) // Replace Battery Now
map.value = "noBattery"
sendAlarm("replaceBatteryNow")
else if (cmd.zwaveAlarmEvent == 0x00) // Battery Replaced
map.value = "batteryReplaced"
sendAlarm("batteryReplaced")
else if (cmd.zwaveAlarmType == 4) // Heat Alarm
map.name = "heatState"
if (cmd.zwaveAlarmEvent == 0) // Normal
map.value = "normal"
else if (cmd.zwaveAlarmEvent == 1) // Overheat
map.value = "overheated"
sendAlarm("tempOverheated")
else if (cmd.zwaveAlarmEvent == 5) // Underheat
map.value = "freezing"
sendAlarm("tempFreezing")
else if (cmd.zwaveAlarmType == 5) // Water Alarm
map.name = "waterState"
map.value = "none"
else if (cmd.zwaveAlarmEvent == 6) // Flow Detected
if(cmd.eventParameter[0] == 2)
map.value = "flow"
else if(cmd.eventParameter[0] == 3)
//log.debug "alarmV2: $cmd"
return map
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
def map = [:]
if(cmd.batteryLevel == 0xFF) {
map.name = "battery"
map.value = 1
map.descriptionText = "${device.displayName} has a low battery"
map.displayed = true
} else {
map.value = cmd.batteryLevel > 0 ? cmd.batteryLevel.toString() : 1
map.unit = "%"
map.displayed = false
return map
def zwaveEvent(hubitat.zwave.Command cmd)
log.debug "COMMAND CLASS: $cmd"
def sendDataToCloud(double data)
def params = [
uri: "https://iot.swiftlet.technology",
path: "/fortrezz/post.php",
body: [
value: data,
email: registerEmail
//log.debug("POST parameters: ${params}")
try {
httpPostJson(params) { resp ->
resp.headers.each {
//log.debug "${it.name} : ${it.value}"
log.debug "sendDataToCloud query response: ${resp.data}"
} catch (e) {
log.debug "something went wrong: $e"
def getTemperature(value) {
if(location.temperatureScale == "C"){
return value
} else {
return Math.round(celsiusToFahrenheit(value))
private getPictureName(category) {
//def pictureUuid = device.id.toString().replaceAll('-', '')
def pictureUuid = java.util.UUID.randomUUID().toString().replaceAll('-', '')
def name = "image" + "_$pictureUuid" + "_" + category + ".png"
return name
def api(method, args = [], success = {}) {
def methods = [
//"snapshot": [uri: "http://${ip}:${port}/snapshot.cgi${login()}&${args}", type: "post"],
"24hrs": [uri: "https://iot.swiftlet.technology/fortrezz/chart.php?uuid=${device.id}&tz=${location.timeZone.ID}&type=1", type: "get"],
"7days": [uri: "https://iot.swiftlet.technology/fortrezz/chart.php?uuid=${device.id}&tz=${location.timeZone.ID}&type=2", type: "get"],
"4weeks": [uri: "https://iot.swiftlet.technology/fortrezz/chart.php?uuid=${device.id}&tz=${location.timeZone.ID}&type=3", type: "get"],
def request = methods.getAt(method)
return doRequest(request.uri, request.type, success)
private doRequest(uri, type, success) {
log.debug(uri)
if(type == "post") {
httpPost(uri , "", success)
else if(type == "get") {
httpGet(uri, success)
def sendAlarm(text)
sendEvent(name: "alarmState", value: text, descriptionText: text, displayed: false)
def setThreshhold(rate)
log.debug "Setting Threshhold to ${rate}"
def event = createEvent(name: "lastThreshhold", value: rate, displayed: false)
def cmds = []
cmds << zwave.configurationV2.configurationSet(configurationValue: [(int)Math.round(rate*10)], parameterNumber: 5, size: 1).format()
sendEvent(event)
return response(cmds) // return a list containing the event and the result of response()
