Is it possible to format variable in RM?
This is what I have now:
But I would like to display only 2 digits after the dot.
I can convert this number to Integer but Decimal with 2 digits after
the dot is desired.
the dot is desired.
You could use variable math. There is a round function. So multiply by 100, round, then divide by 100. Variable math can be found in Set Variable, and works for decimal or integer values.
Thank you very much, Bruce.
The suggested trick worked very well:
