Format for "Custom RGB Color" when Setting Color
I'm trying to set a custom bulb color for a Nanoleaf Essentials A19 in Rule Machine, but can't figure out the proper format for the input box which gives "#rrbbgg" as the hint.
TIA
Standard 6 hex digit number, e.g. #425A7F, for the color.
Thanks for the reply... It works for me if I use a string variable, but it won't take a hard value into the input box. It just removes it, and returns to the hint as soon as I take focus away.
Need more context for where you are seeing this please.
Rule Maker-> Create New Action-> Set Dimmers and Bulbs-> Set Color
Yep, looks as though some dev test code was left in there for some reason. Small fix. This will be in the 2.4.0 release.
Thanks, Bruce!!
