Anyone have any recommendations for a smart equivalent of these? I have cans of two different sizes in our basement which I’d like to add tunable white LEDs to — so that they can match the circadian color temperature routine I have setup on the rest of the house, controlled by Node Red+Hubitat.
I currently have a bunch of sengled bulbs but I’m not committed to that brand as long as they’re Hubitat friendly.
Might be easier/cheaper to just put in a zigbee/zwave switch unless you need to address each light (i.e. color variations, etc.)
Does look like Hue produces some
Any light that is powered by an in-wall switch I highly recommend you use non-smart LED bulbs in the fixtures and then use a single in-wall smart switch to control them. Otherwise you have the potential issue someone in the house turns off the wall switch which then renders all the smart bulbs useless.
Thanks for the suggestion to use a switch. The reason I want bulbs is so I can control the color temperature throughout the day. I use smart bulbs with smart/dumb switches depending on the other uses of the room and it generally works great.
We have this system on every bulb in our house, but I prefer the look of the flush mount LEDs instead of bulbs hanging in the can socket.
Sylvania/Osram/LEDVance (whatever they are calling themselves now
) has one.
https://www.amazon.com/dp/B015KQ29JI/
