Flume integration
Because my Flume had the original battery case, you can just put new lithium batteries directly into it.
If you have the newer gray battery case then it becomes more complicated.
But what I was referring to was the battery replacement where you're running off hardwired power not batteries, a conversion that @hydro311 had done.
perfect -- Im probably going to do this mod. https://www.youtube.com/watch?v=8sL016BuOqk
My flume is not outside, so Im also going to have the batteries external to the box so I dont have to detach it everytime, which is more painful because of where its located ...
Hi,
I had Flume running great and working with no issues for Months/years.
2 days ago it stopped reporting but I can see data coming in the debug logs but not in the Hubitat device nor in my Grafana (Influx DB).
This is what I see in the logs but having hard time to understand where is the issue.
I did try to remove and recreate the device again but it ends with the same exact results.
dev:9612025-05-10 05:55:05.418 AMerror
error: status code: 400, reason phrase: Bad Request @ Line: 986
dev:9612025-05-10 05:55:05.415 AMdebug
httpPostExec() failed: status code: 400, reason phrase: Bad Request
dev:9612025-05-10 05:55:05.193 AMdebug
