Flicker-free light bulb database
I was searching for flicker-free dimmable E12 candelabra bulbs and came across a light bulb database that I haven't seen mentioned here before.
While it isn't as extensive as Lutron's LED compatibility database, the flicker-free ratings on OptimizeYourBiology's light bulb database seem to be very reliable.
I found E12 bulbs and E26 bulbs that are reliably flicker-free with Zooz dimmers, whereas the Feit bulbs they replaced would occasionally flicker.
Here's the database:
They also have a smart bulb database, with flicker ratings.
Knowing your dimmer technology type is critical. Leading VS trailing etc.
Is there an anti flicker downlight data base?
Might you be able to help guide selection of an appropriate non flicker down light for this dimmer please?
