I was reading the top of the thread and the first thing I thought was the same thing, funny I saw your comment when I got to the bottom of the thread
you have to have the Flic hub, right? I've only got buttons...
Hey Jason,
Is there any way you could help me out? I'm new to all of this, and have a Flic Hub that I'd like to use. This is what I've done so far.
Using the Flic Hub, I assigned a click to do an Internet Request. I put "http://[HubitatIP]/apps/api/23/devices/[thedeviceID]/push/?access_token=[theaccesstoken]"
Then on Hubitat, I added the Maker API. I created a virtual button called Flic and selected it in the preferences of the Maker API.
Then I used the Rule engine to create an action. When the Flic virtual button is pushed, then something will happen. Not sure what else to do. I noticed you used 81 in between the api and devices slashes in the HTTP GET request, but in my Maker API it was saying 23. Not sure what that number represents anyway.
Any ideas or ways you could help me? I am a teacher and I'm trying to integrate the Flic buttons in my classroom. Thanks in advance for any help you can offer!
Dan
Hi Dan. I believe the 81 (for me) and 23 (for you) are the app ID of the Maker API on our installations. You should stick to whatever the Maker API shows in the generated URLs.
It looks like you may have left out the button number, also known as the 'Secondary Value' for the command. It's the last parameter, just before the "?access_token"
Try adding the button number and see how you go.
Sorry for the slow reply. I haven't tried it without the Hub, and I'm away from home now, so can't really test this out, but you could see if the Flic app on your phone will also allow Internet Requests to be triggered by Flic Buttons without a Hub.
Of course, these buttons will only work if the phone is within Bluetooth range of the buttons.
Looks like you've missed the button number from your Flic string.
My strings look like this:
http://HUB IP ADDRESSS/apps/api/615/devices/1314/push/1?access_token=3c80987e-c91b-49ba-b785-74dde0541978
note the " push/1? "
Give that a go.
My Flic Doorbell (with Flic Hub) works great.
Just wanted to circle back to this thread and mention the Flic for Mac app. It's been publicly available since September of last year, but I have not been up to speed on what they were doing, since I am so over my love of their ridiculously expensive button, in favor of mesh capable Xiaomi Zigbee buttons, or even a Samsung SmartThings button.
However, when I was about to order another Xiaomi button last night, it occurred to me to find out what was happing in the Flic world. So I was quite pleased to discover their Mac app. For me personally, this make quite a lot of sense. I hated the Idea that I needed to either kill a perfectly good battery on a spare iPhone by leaving it plugged in all the time. And it was laughable that I would every spend over $100 US for their hub to serve a single $35 flic button.
To my delight, there is now a Mac app which can run in the background of my MacBook Pro, which is always running anyway to serve Homebridge, Google Home Assistant, Castweb API and Insteon Server for HE Insteon support. So this is a no brainer for me, as I already own this button that was previously pretty useless to me. Just as the iOS app and their hub does, the Mac app works perfectly with HE local end points! Much faster and more reliable than was previously possible with cloud end points.
thanks, very helpful
@jason-lane Hi Jason, I'm very new with hubitat and also has got flic hub.
I've read your instructions, but since I'm very new with hubitat, I'm slightly confused with the Maker API bit.
I've created the virtual button as you have put in you instruction. I put 2 because I only have 2 buttons.
but this is where I'm slightly lost....Is it correct that I can only create 1 action per Maker API? because I can only enter 1 url (for 1 action)
If you can send me some of screenshots, then that'll be much appreciated.
Edited:
Do I then enter the same URL in both Maker API and the button?
Do I leave the Allowed Hosts (for CORS) blank?
Do I still need to select the delivery for the "Allow Endpoint to Control These Devices" section?
sorry for the many questions
Hi All, just wondering if anyone can help me on this? Cheers
Sorry for the delay, I was travelling and didn't get a chance to read your post.
First of all, did you read the updated part of my post, where I recommended creating one Virtual Button device for each button? This makes things a little simpler. eg. I have one Flic button that I'm using as a doorbell, so I created a Virtual Button device in Hubitat called "Doorbell Flic Button", and specified that it has 1 physical button.
Now, I'm not sure what you mean about creating 1 action per Maker API? You don't create any actions there. The Maker API just exposes a device to API commands. You need to select the button (eg. Doorbell Flic Button) in the "Allow Endpoint to Control These Devices."
I did not use the "Allowed Hosts" section.
Once you specified your devices in Maker API, look for the URL near the bottom, which says "Send Device Command (replace [Device ID] with actual subscribed device id and [Command] with a supported command. Supports optional [Secondary value]"
Mine looks like http://192.168.xxx.xxx/apps/api/81/devices/[Device ID]/[Command]/[Secondary value]?access_token=abcdefgh
Copy this URL, then edit it with the Device ID of you virtual button device, the Command (push/doubleTap/held), and Secondary Value (physical button). This is the URL that you paste into the Flic app as an Internet Request action. For me, it would look something like:
http://192.168.1.123/apps/api/81/devices/130/push/1?access_token=abcdefgh
Note that the number 81 will be different for you. This is the App ID for the Maker API in my Hubitat.
Thanks @jason-lane, I had to learn and understand how maker-api works. Have just now circled back around and got it working! Cheers
I came here to write this, It is worth noting that you can replace push
with held
and doubleTap
to add all the button functions.
Flic have released their SDK for on hub coding. Allows buttons to do specific TCP HTTP UDP and IR actions based on various press types. Executed locally on hub. Includes UDP broadcast TX and RX it seems too. Should allow some interesting integration possibilities with HE.
I'm trying to figure out what improvement this sdk would bring since my flics are allready fully integrated into hubitat as buttons with local calls to the hub.
I can't find any. Anyone has a better view?
I would love to get my Flic hub integrated into Hubitat for two reasons. First, I'd like to have my Flic buttons' battery statuses sent back to Hubitat. I have some alert notifications set up for my battery-driven devices, and I would like to see them all in one place. The Flic app does provide a low battery warning, but it's very vague and doesn't provide a specific percentage of useable life left.
The additional thing I'd like to do is to be able to control the Flic's connected IR blaster. I'd like to set up some routines so it automatically fires at certain times of the day, or under certain conditions.
It looks like someone has done some work to integrate the Flic hub with Home Assistant, and I've tried mucking about with that code, but with the most minimal success so far. It seems like it would be a pretty straightforward integration if it was done by someone who actually knew what they were doing.
Hi Thanks for the detailed instructions and sorry for digging up an old thread.
I was able to get all this to work for the push and doubleTap commands, but for some reason when I try to do a HELD command, I get this following error in the hubitat log for the Maker API instance:
java.lang.NullPointerException: Cannot invoke method getAt() on null object on line 460 (method sendDeviceCommandSecondary)
This happens if I try to execute the HOLD from the flic app or the flic button itself.
But if I go to the device in hubitat and do a manually initiate a "Hold" it works fine(turns on a light in my case using Basic Rule app).
Any ideas? Is this a maker API thing? Thank you
Here are the 3 strings I'm using with the same physical button. First 2 work(push double tap) work fine, but the 3rd(held) doesn't. 3 different instances of Maker API and 3 different virtual buttons
http://192.168.86.68/apps/api/54/devices/18/push/1?access_token=cbc99a49-55a5-486e-991b-4150e462XXXX
ok I feel stupid answered my own question - the command options are actually push, doubleTap, hold, release. HELD is not a valid command, and release can't be programmed into the flic button
