You could just setup a virtual switch that you either toggle manually each year yourself, or setup some kind of rule that looks to see if we are between two dates.
Depending on how consistent they are and how closely they align to regular weather seasons, this may also be useful:
In your lighting rules use the switch to control the timeouts of your lighting. You may need to do this through RM rules at this stage, but I could be wrong.
