Ahhhh, thanks for the input. Maybe two rules are best. I'm just making the switch to Hubitat so rule making and this style of conditional language is new for me; I'm still on the steep side of the learning curve.
You don't need to do it as 2 rules as what you did is correct.
You may need to choose a time period that they dim over and then have them turn off as not all bulbs will turn off at 0% brightness.
I think you can do it in one rule and just use the 'wait' command. So trigger would be sunrise, actions would be your fade up then wait till sunset and start fade down.
My intention was good but after going to bed late, when the alarm went off at 5:25 well....no bueno.
BUT, when I came downstairs long after the rule had expired, 4 of the 5 lights (all Lightify) were dimmed down to as low as possible...not off; The Hue bulb in the rule was OFF albeit, I don't know if it ever came on with the trigger....I was snoring.
Soooo, it looks like the last action of turning the bulbs off, didn't work.
Also, looking at my Sunriser rules' events, it shows triggered.
