I have been struggling to create a rule to achieve what appears to be a simple task.
I want a z-wave smart plug to switch on every evening at 22:00 and off again at 08:00 the next morning. The complication is that I also want the same smart plug to switch on when Life360 says 'Away' and to switch off again when Life360 says 'Home; except if the Home time falls between the normal 'on' time of between 22:00 and 08:00.
I would appreciate any pointers for the best way to attack this project. I am not at all sure that it can be done in one set of rules.
I have no problems in getting the regular daily function to work properly. The problems start when I try to involve the Home/Away aspect.
I have attached a GIF that illustrates what I am trying to do.
I agree with @destructure00, I think you are making it overly complicated. I believe his rule will work for your requirement. Look under his Define Rule definition:
(Time) (Present or Not)
10:30 PM OR Home
TRUE OR FALSE = FALSE = LIGHT ON
10:30 PM OR Away
TRUE OR TRUE = TRUE = LIGHT ON
5:00 PM OR Home
FALSE OR FALSE = FALSE = LIGHT OFF
5:00 PM OR Away
FALSE OR TRUE = TRUE = LIGHT ON
Hopefully you understand my rudimentary explanation
Thank you all for taking the trouble to break down the elements of my problem and presenting them clearly for me. As I have had just a day to get to grips with Rule Machine I will need to do a bit of work based on the above.
Many thanks.
