Hubitat noob. I have some Lutron Pico remotes set up to change Hubitat’s mode. Then, IFTTT detects the mode change and controls Alexa routines.
I’m having trouble making my First Alert alarm trigger a mode change to accomplish the same control of Alexa routines.
Ok, that was the simple phrasing. What I’m really trying to accomplish is for when the Z-wave alarms trigger, my furnace with ecobee t-stat, pellet stove on geekbee, and coffee maker on geekbee turn off and all my lights turn on. My smart home is set up with whatever was on sale and works very well through Alexa. I got the Hubitat in hopes of the smoke detector integration, Lutron Pico buttons, and in the future, door lock integration.
I agree, from what you’re describing, changing modes is not what you’re looking to do here.
Hubitat safety monitor can trigger several different kinds of actions when a z-wave smoke detector goes off. You probably need to use a virtual switch to work with IFTTT and a WiFi plug like geekbee though.
What’re you doing to try to trigger the alert? AFAIK, pushing the test button on the device doesn’t trigger an alert. You’d have to use smoke in a can or create a source of smoke (carefully).
I’ve triggered with a burnt match to no avail. Tried the generic driver and the user driver. I can’t get a trigger to work. My wife is pissed at my testing... hehe
I am wrong on this one. Just tested and for smoke carbon monoxide detector with Generic Z-Wave Smoke/CO Detector. I get this
dev:11512018-11-25 11:27:29.304 am infoSafety smoke kitchen battery is 100% dev:11512018-11-25 11:27:29.202 am infoSafety smoke kitchen carbon monoxide is clear dev:11512018-11-25 11:27:29.200 am infoSafety smoke kitchen smoke is clear dev:11512018-11-25 11:27:12.605 am infoSafety smoke kitchen carbon monoxide is test dev:11512018-11-25 11:27:12.599 am infoSafety smoke kitchen smoke is test
With just the smoke detector with Generic Z-Wave Smoke Detector. I get dev:11522018-11-25 11:26:26.377 am infosafety smoke 3rd floor battery is 95%
Just found this thread... I too am trying to verify that my smoke alarm is going to notify pushover, but after much frustration attempting to test by pushing the "test" button failed to send an alert I am guessing that besides lighting a fire, there is still no "test" function? I suppose I could use RM?
