I'm just getting started with Hubitat and am practicing with a couple of simple zwave devices including a new first alert 2in1 detector. I added the detector as a generic detector device using the built in driver and then added it to my dashboard as a smoke detector and as a CO detector. Question is whether i can get at any other device attributes on the dashboard such as battery level, health checks, CO level, etc.?
From the Hubitat homescreen, I select devices. This gives me a list of devices I have added. When I select the FirstAlert I do not see anything that says "attribute." Am I in the wrong area?
on each device page, on the right, next to the row of buttons is a column labeled Current States.
Some devices have tiny lists:
Some have more, as I pasted above.
They are organized as two word, pairs. The left is the attribute name, the right is the value. Copy/paste the attribute name you're interested in into a Dashboard tile and the right word (value) will be displayed.
Okay, I think I'm catching on. I see "Battery" "Smoke" and "CarbonMonoxide" as attributes. Presumably the generic built in driver only includes those. I wonder whether there is a more specific driver that can get at more info? Are Z-wave drivers hubitat specific or are they platform independent?
I don't own a ZWave Thermostat, mine's a WiFi so I have a completely different driver. However, when I create a device and assign it the Generic ZWave Thermostat driver, I get no Current States:
The next step would be to click the Configure button. That button causes your Hub to send the ZWave commands THIS driver thinks it needs. When the Thermostat answers, you would get the results in Current States. There may be more info that won't show in Current States til the device does something and tells the Hub.
Those are the exact ones I have as well. I don't think this detector reports levels, there is nothing in manual about it being able to. It just trips or not. You can add tiles that will show clear or tripped and also battery level.
