Firmware Updater app is incompatible with Z-wave LR when using Z-wave JS
@bcopeland @gopher.ny
Seems the firmware updater app is incompatible with Z-wave LR when using the Z-wave JS. Can we get an update to make it work? It simply doesn't list any Z-Wave LR devices when trying to select a target unless reverting to Z-Wave Zip.
Thanks in advance!
Confirmed. My LR device on my test hub is missing from the list when on ZWJS
Yup
Previously (I think) it wasn't possible to update firmware on an LR device without reverting to a mesh inclusion.
Is this a ZWJS capability, a recent firmware capability or am I generally misinformed?
That was just due to the tools on he hub not being setup for LR devices, it was fixed at some point before ZWJS was available so that the updater app does work on LR devices. I also fixed the "driver" version myself just to see if it would work (not published). But now it seems for some reason on ZWJS it does not see the LR devices, seems like it should be a pretty simple fix. Once the devices are selectable in the list, I would assume it will work.
