Firmware 2.5.3.133: Did something change with logsocket?
Hub C-8 - just upgraded from 2.5.0.xxx to 2.5.3.133. I have a Node-RED flow with a web socket listener node that captured the log stream from the hub. It has been working perfectly for many years but after upgrading to the latest firmware, the node will not connect
I have restarted Hubitat and Node-RED. I do have login security enabled but it was never used for logsocket stream. Was there some change with the latest update? Any workaround?
They may have added pairs to the message, but using Websocket Client on my Mac, it looks fine:
2.5.3 now requires authentication on the log websockets.
Which client are you using? Any idea how to duplicate this in Node-RED? Also, it looks like my Node-RED login flow to HE is now broken :disappointed_face:
Very easy for Node-Red:
Find a WebSocket node, I picked:
Setup to listen to a Hub was easy too:
It really just wants your Hub's URL: ws://<your_hub_IP>/logsocket and I picked the Auth Mode that matches my need.
Do you have security enabled on your hub? I had it set up the same way but with the built-in websocket client. However, I have security enabled and it broke with the latest firmware.
With some serious help from Gemini, I managed to get this working. Since I had hub security enabled, 2.5.3.XXX also broke my Node-RED login subflow but it's all fixed now. :crossed_fingers:t3:
I do remember reading that security got added to logstream, but since I don't have it enabled, it made it to the ignore pile instantly. And, I don't use logstream either. :smiley:
I'm STILL using HubConnect and it's tied to eventstream.
I don't use HubConnect, however according to my tests, both /eventsocket and /logsocket now require auth when hub security is enabled, on 2.5.3. /zigbeeLogsocket and /zwaveLogsocket don't.
With Gemini's help, I was able to substitute the websocket in node with a function node (configured to use the npm ws library). And I updated the Hubitat Login subflow ( Node-RED subflow: Hubitat Login with hub security enabled and FW 2.5.3.133 ) to send in the credentials, so it's all working now!
