Yea, I know the obvious answer is a big NO, once the Fire TV Sticks are controlled by Bluetooth. I already use a Logitech Harmony Touch with a hub, which allows the basic control - except the use of the four dedicated buttons, my main interest.
Searching for solutions, I found apps that lets you control your device with your mobile as long as they are connected to the same network.
Well, if I´m not wrong this makes it assume that there is some kind of control of this kind of device through ip. And if it is controllable via IP, is there any way to control it through Hubitat, developing a driver, perhaps?
I did a search on HA and there appear to be some methods for sending notifications TO the Fire TV (to display on the screen) so maybe there is some code somewhere behind that...
Hi @terminal3! I already use Echo Speaks, but I would like to be able to send commands through RM to use it in automations, by example, to open a specific app contained in the Fire TV. I already do that trough Logitech Harmony hub, but I don't want to be dependent of a discontinued device...
Guys, thanks a lot to everyone that tried to help!
I'll try the solution indicated by @terminal3 not only for the simplicity of implementation but because I believe it will meet my need. Thanks @terminal3, I hadn't thought about that approach.
