Any wifi devices you integrate should have a DHCP reservation including hubitat itself. That way after reboot or power failure everything can be found properly.
Ah, kindred souls indeed, then.
I sense a lack of faith in this one...
Today I learned a Quebec swear word:
Tabarnak
The "tabernacle" refers to the portable house of God/holiest of holy places carried out of Egypt by the Isrealites and used for worship during their many wanderings, in place of a temple. Basically an equivalent to F#CK, only it actually refers to a decked out porta-Church with its own sacrificial altar.
Of course, although I know the reference, I don't understand the swearing aspect.
@Ranchitat and @aaiyar I bought a box of Kasa Smart Wi-fi Plug Minis and a Kasa Smart WiFi Outdoor Plug to bring everything into alignment per your suggestion. However, in the Hubitat Elevation app, and the Web portal, there is no listing for these devices in the Add a Device path. Am I missing something? Should I be setting these up with Amazon Echo or the Kasa app and then "discovering" them through the Hubitation UI, or something else?
You'll need to use a built in app to add/control Kasa devices, start here:
It's pretty straight forward, first time takes a little longer but overall it's pretty quick.
Just try and set up DHCP reservations for your Kasa devices on your router right from the start.
And if you get stuck you can check the original and related, but no longer required since it's now built-in, mega-thread instructions here.
Thanks, I'll check that out.
