Fibaro Z-Wave Plus Flood and Temperature Sensor FGFS-101 ZW5
I just paired a new Fibaro Z-Wave Plus Flood and Temperature Sensor FGFS-101 ZW5 and it paired fine however it was detected as a device rather than the Fibaro driver. Once I switched to the correct driver and hit configure it worked. I powered it via the 12v option rather than the battery if that makes any difference?
deviceType: 2817
deviceId: 8195
inClusters:
0x5E,0x22,0x85,0x59,0x70,0x56,0x5A,0x7A,0x72,0x8E,0x71,0x73,0x98,0x9C,0x31,0x86
manufacturer: 271
Tagging @mike.maxwell he'll need to add the info to the stock driver to correctly identify the device when used with the 12v option likely.
I’ll take a look.. May need a fingerprint update
