Is there an easy way to find out what "states" are supported by the integrated driver code?
I have a Fibaro Window Door Sensor 2 (FGDW-002) which is reporting the following states:
- contact
- temperature
- tamper
However I believe is is also capable of reporting battery level but this is not showing up....
I am trying to understand if this is because this state is not made available in the driver code (IE I need to modify) or something is not quite playing ball
