I have a Fibaro The Button, which works perfectly on SmartThings using the official device handler from github/richb1. Can't get it working with Hubitat though, in a way which I simply don't understand - though I'm happy to admit there's a lot I don't understand!
The device pairs, but although I've added in the (suitably modified) Fibaro driver which has appropriate footprints, it's picked up as a Generic Z-Wave Button Controller. It's picked up correctly by the footprint as a Fibaro Button in SmartThings.
The real trouble comes with the zwave.parse
method - this always seems to return Crc16Encap(checksum:null, command:null, commandClass:null, data:null)
, and behaves the same whether in the generic or Fibaro driver. My understanding (evidently flawed) was that if parsing fails this would return null, not an object full of null values. Regardless of that, it looks like there's something wrong in either the command or the parsing.
The equivalent result of zwave.parse
in SmartThings is like SecurityMessageEncapsulation(secondFrame: false, commandIdentifier: 3, commandClassIdentifier: 91, commandByte: [4, 128, 1], sequenceCounter: 0, sequenced: false, reserved13: 0)
The string input for those two results are respectively: Hubitat zw device: 07, command: 5601, payload: 5B 03 03 80 01 26 98 BF 00
and SmartThings zw device: 1F, command: 9881, payload: 00 5B 03 04 80 01
I've reincluded, with no change in behaviour.
Any help would be appreciated.
