I ported my ST handler over a long time ago, but I can't remember if it was before or after Hubitat's new button implementation. I also don't remember how functional it was and I don't have time to re-test it so I'm posting it as-is...
It it doesn't work well let me know and I'll remove this post.
* Fibaro Swipe Gesture Controller v1.0
* (Model: FGGC-001)
* Author:
* Kevin LaFramboise (krlaframboise)
* Changelog:
* 1.0 (08/30/2017)
* - Initial Release
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (
name: "Fibaro Swipe Gesture Controller",
namespace: "krlaframboise",
author: "Kevin LaFramboise"
capability "Sensor"
capability "Button"
capability "Battery"
capability "Configuration"
capability "Refresh"
attribute "status", "string"
attribute "lastCheckin", "string"
attribute "lastUpdate", "string"
attribute "pendingChanges", "number"
gestures.each {
attribute "${it.btnNum}".length() < 2 ? "button0${it.btnNum}" : "button${it.btnNum}", "string"
fingerprint deviceId: "2000", inClusters: "0x5E,0x85,0x59,0x80,0x5B,0x70,0x56,0x5A,0x7A,0x72,0x8E,0x73,0x98,0x86,0x84", outClusters: "", mfr:"010F", prod:"0D01", deviceJoinName: "Fibaro Swipe"
preferences {
getOptionsInput(deviceOrientationParam)
getOptionsInput(powerSavingModeParam)
getOptionsInput(ledModeParam)
getOptionsInput("buzzer", "Buzzer Mode", buzzerSetting, buzzerOptions)
getBoolInput("doubleSwipeEnabled", "Enable Double Swipe Gestures?", doubleSwipeEnabledSetting)
gestures.each { gest ->
if (gest.seqNum) {
getOptionsInput("seq${gest.seqNum}", "${gest.name} Gestures", getSeqSetting(gest.seqNum), seqOptions)
getOptionsInput("wakeUpInterval", "Checkin Interval", checkinIntervalSetting, checkinIntervalOptions)
getOptionsInput("batteryReportingInterval", "Battery Reporting Interval", batteryReportingIntervalSetting, checkinIntervalOptions)
getBoolInput("debugOutput", "Enable debug logging?", debugOutputSetting)
private getTextInput(name, title, defaultVal) {
input "${name}", "text",
title: "${title}:",
defaultValue: defaultVal,
required: false
private getBoolInput(name, title, defaultVal) {
input "${name}", "bool",
title: "${title}",
required: false
private getOptionsInput(name, title, defaultVal, options) {
return getOptionsInput([
prefName: "${name}",
val: defaultVal,
options: options
private getOptionsInput(param) {
input "${param.prefName}", "enum",
title: "${param.name}:",
defaultValue: "${param.val}",
required: false,
displayDuringSetup: true,
options: param.options?.collect { name, val -> name }
def updated() {
state.lastUpdated = new Date().time
logTrace "updated()"
syncSettingAttributes()
if (checkForPendingChanges()) {
logForceWakeupMessage("The configuration will be updated the next time the device wakes up.")
return []
private syncSettingAttributes() {
gestures.each {
def labelAttr = "${it.btnNum}".length() < 2 ? "button0${it.btnNum}" : "button${it.btnNum}"
def labelVal = "${it.name}"
if (!doubleSwipeEnabledSetting && it.name.contains("Double")) {
labelVal = "[Double Swipe Disabled]"
else if (it.seqNum) {
labelVal = "Sequence ${it.seqNum}: ${getSeqSetting(it.seqNum)}"
if (getAttrValue(labelAttr) != labelVal) {
sendEvent(createEventMap(labelAttr, labelVal, false))
def configure() {
logTrace "configure()"
def cmds = []
sendEvent(name: "status", value: "Configuring...")
if (getAttrValue("button") == null) {
sendEvent(name: "button", value: 1)
sendEvent(name: "numberOfButtons", value: gestures.size())
sendEvent(name: "holdableButton", value: false)
logTrace "Waiting 1 second because this is the first time being configured"
cmds << "delay 1000"
if (state.refreshAll || state.checkinIntervalSeconds != checkinIntervalSettingSeconds) {
cmds << wakeUpIntervalSetCmd(checkinIntervalSettingSeconds)
cmds << wakeUpIntervalGetCmd()
configParams.each { param ->
cmds += updateConfigVal(param)
if (!cmds) {
resetStatus()
return cmds ? delayBetween(cmds, 1000) : []
private updateConfigVal(param) {
def result = []
if (hasPendingChange(param)) {
def newVal = getParamIntVal(param)
logDebug "${param.name}(#${param.num}): changing ${getParamStoredIntVal(param)} to ${newVal} (${getConfigValueName(param, newVal)})"
result << configSetCmd(param, newVal)
result << configGetCmd(param)
return result
private checkForPendingChanges() {
def changes = 0
if (state.checkinIntervalSeconds != checkinIntervalSettingSeconds) {
changes += 1
configParams.each {
if (hasPendingChange(it)) {
changes += 1
if (changes != getAttrValue("pendingChanges")) {
sendEvent(createEventMap("pendingChanges", changes, false))
return (changes != 0)
private hasPendingChange(param) {
return (getParamIntVal(param) != getParamStoredIntVal(param) || state.refreshAll)
// Required for HealthCheck Capability, but doesn't actually do anything because this device sleeps.
def ping() {
logDebug "ping()"
return []
def refresh() {
sendEvent(createEventMap("pendingChanges", configParams.size(), false))
state.refreshAll = true
logForceWakeupMessage("The sensor data will be refreshed the next time the device wakes up.")
return []
def result = []
// logTrace "parse: $description"
if (!isDuplicateCommand(state.lastCheckin, 60000)) {
state.lastCheckin = new Date().time
result << createEvent(name: "lastCheckin", value: convertToLocalTimeString(new Date()), displayed: false, isStateChange: true)
if (!description?.startsWith("Err")) {
def cmd = zwave.parse(description, commandClassVersions)
if (cmd) {
// logTrace "Parse: $cmd"
result += zwaveEvent(cmd)
else {
logDebug "Unable to parse description: $description"
return result
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
def result = []
def encapCmd = cmd.encapsulatedCommand(commandClassVersions)
if (encapCmd) {
// logTrace "secure cmd: $encapCmd"
result += zwaveEvent(encapCmd)
else {
log.warn "Unable to extract encapsulated cmd from $cmd"
return result
def zwaveEvent(hubitat.zwave.commands.crc16encapv1.Crc16Encap cmd) {
log.trace "Crc16Encap: $cmd"
def result = []
def cmdClass = getVersionSafeCmdClass(cmd.commandClass)
def parsedCmd = cmdClass?.command(cmd.command)?.parse(cmd.data)
if (parsedCmd) {
logTrace "Parsed crc16: ${parsedCmd}"
result += zwaveEvent(parsedCmd)
else {
log.warn "Unable to parse crc16encap command"
return result
def zwaveEvent(hubitat.zwave.commands.wakeupv2.WakeUpNotification cmd) {
logTrace "WakeUpNotification: $cmd"
def result = []
result += configure()
if (canReportBattery()) {
result << batteryGetCmd()
if (result) {
result << "delay 1200"
result << wakeUpNoMoreInfoCmd()
return response(result)
def zwaveEvent(hubitat.zwave.commands.wakeupv2.WakeUpIntervalReport cmd) {
logTrace "WakeUpIntervalReport: $cmd"
def result = []
state.checkinIntervalSeconds = cmd.seconds
runIn(1, finalizeConfiguration)
return result
private canReportBattery() {
def reportEveryMS = (convertOptionSettingToInt(checkinIntervalOptions, batteryReportingIntervalSetting) * 1000)
return (!isDuplicateCommand(state.lastBatteryReport, reportEveryMS))
def zwaveEvent(hubitat.zwave.Command cmd) {
log.warn "Unhandled Command: $cmd"
return []
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
logTrace "BatteryReport: $cmd"
def result = []
def val = (cmd.batteryLevel == 255 ? 1 : cmd.batteryLevel)
if (val > 100) {
val = 100
state.lastBatteryReport = new Date().time
logDebug "Battery ${val}%"
result << createEvent(createEventMap("battery", val, null, null, "%"))
return result
def zwaveEvent(hubitat.zwave.commands.configurationv2.ConfigurationReport cmd) {
def result = []
logTrace "ConfigurationReport: (paramNum: ${cmd.parameterNumber}, configValue: ${cmd.configurationValue}, size: ${cmd.size}"
if (getAttrValue("pendingChanges") != -1) {
result << createEvent(createEventMap("pendingChanges", -1, false))
def val = convertToScaledValue(cmd.configurationValue, cmd.size)
def configParam = configParams.find { param ->
param.num == cmd.parameterNumber
if (configParam) {
logDebug "${configParam.name}(#${configParam.num}) = ${getConfigValueName(configParam, val)} (${val})"
state["configVal${cmd.parameterNumber}"] = val
else {
logDebug "Parameter ${cmd.parameterNumber} = ${val}"
runIn(2, finalizeConfiguration)
return result
private getConfigValueName(param, val) {
def options = param?.name?.contains("Sequence") ? seqOptions : param?.options
return options?.find { it.value == val}?.key ?: "$val"
private convertToScaledValue(val, size) {
if (size == 2) {
return val[1] + (val[0] * 0x100)
else {
return val[0]
def finalizeConfiguration() {
logTrace "finalizeConfiguration()"
state.refreshAll = false
resetStatus()
sendEvent(createEventMap("lastUpdate", convertToLocalTimeString(new Date()), false))
return []
def zwaveEvent(hubitat.zwave.commands.centralscenev1.CentralSceneNotification cmd) {
// logTrace "CentralSceneNotification:[sceneNumber:cmd.sceneNumber, keyAttributes:${cmd.keyAttributes}, sequenceNumber:${cmd.sequenceNumber}]"
def result = []
def gesture = gestures.find{ it.sceneNum == cmd.sceneNumber && it.keyAttr == cmd.keyAttributes }
if (gesture) {
def status = "${gesture.name} / Button ${gesture.btnNum} Pushed"
result << createEvent(createEventMap("button", gesture.btnNum, true, status))
result << createEvent(createEventMap("status", status, false))
if (!gesture?.name?.contains("Start")) {
runIn(3, resetStatus)
else {
log.warn "Unknown Gesture: [sceneNumber:cmd.sceneNumber, keyAttributes:${cmd.keyAttributes}, sequenceNumber:${cmd.sequenceNumber}]"
return result
def resetStatus() {
sendEvent(createEventMap("status", "Ready", false))
private wakeUpIntervalSetCmd(val) {
return secureCmd(zwave.wakeUpV2.wakeUpIntervalSet(seconds:val, nodeid:zwaveHubNodeId))
private wakeUpIntervalGetCmd() {
return secureCmd(zwave.wakeUpV2.wakeUpIntervalGet())
private wakeUpNoMoreInfoCmd() {
return secureCmd(zwave.wakeUpV2.wakeUpNoMoreInformation())
private batteryGetCmd() {
return secureCmd(zwave.batteryV1.batteryGet())
private configSetCmd(param, val) {
return secureCmd(zwave.configurationV2.configurationSet(parameterNumber: param.num, size: param.size, configurationValue: convertFromScaledValue(val, param.size)))
private convertFromScaledValue(val, size) {
if (size == 2) {
return [(byte) ((val >> 8) & 0xff),(byte) (val & 0xff)]
else {
return [val]
private configGetCmd(param) {
return secureCmd(zwave.configurationV2.configurationGet(parameterNumber: param.num))
private secureCmd(cmd) {
if (zwaveInfo?.zw?.contains("s") || ("0x98" in device.rawDescription?.split(" "))) {
return zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
else {
return cmd.format()
private getCommandClassVersions() {
0x20: 1, // Basic
0x56: 1, // Crc16 Encap
0x59: 1, // AssociationGrpInfo
0x5A: 1, // DeviceResetLocally
0x5B: 1, // Central Scene (2)
0x5E: 2, // ZwaveplusInfo
0x70: 2, // Configuration (1?)
0x72: 2, // ManufacturerSpecific
0x73: 1, // Powerlevel
0x7A: 2, // Firmware Update Md (3)
0x80: 1, // Battery
0x84: 2, // WakeUp
0x85: 2, // Association
0x86: 1, // Version (2)
0x8E: 2, // Multi Channel Association (3)
0x98: 1 // Security
private getVersionSafeCmdClass(cmdClass) {
def version = commandClassVersions[safeToInt(cmdClass)]
if (version) {
return zwave.commandClass(cmdClass, version)
else {
return zwave.commandClass(cmdClass)
// Configuration Parameters
private getConfigParams() {
def params = [
deviceOrientationParam,
buzzerModeParam,
buzzerEnabledParam,
ledModeParam,
toggleModeParam,
lifelineScenesParam,
// poweringModeParam
params += seqParams
return params
private getSeqParams() {
def params = []
(1..6).each {
params << createConfigParamMap((it + 30), "Sequence ${it}", 2, null, null, (convertOptionSettingToInt(seqOptions, getSeqSetting(it))))
return params
private getDeviceOrientationParam() {
return createConfigParamMap(1, "Device Orientation", 1, ["Default Orientation${defaultOptionSuffix}":0, "180 Degree Rotation":1, "90 Degree Clockwise Rotation":2, "90 Degree Counter-Clockwise Rotation":3], "deviceOrientation")
private getPowerSavingModeParam() {
return createConfigParamMap(6, "Power Saving Mode", 1, ["Standby Mode (Hold Gesture Required)${defaultOptionSuffix}":0, "Simple Mode (Slow Gestures)":1, "Power Saving Disabled":2], "powerSavingMode")
// private getPoweringModeParam() {
// return createConfigParamMap(5, "Check if powered by USB every", 2, null, "powerSavingMode")
private getLedModeParam() {
return createConfigParamMap(3, "LED Mode", 1, ["Disabled${defaultOptionSuffix}": 0, "Enabled":1], "ledMode")
private getBuzzerEnabledParam() {
return createConfigParamMap(2, "Buzzer Enabled", 1, null, null, (convertOptionSettingToInt(buzzerOptions, buzzerSetting) > 0 ? 1 : 0))
private getBuzzerModeParam() {
return createConfigParamMap(4, "Buzzer Mode", 1, null, null, (convertOptionSettingToInt(buzzerOptions, buzzerSetting) ?: 3))
private getLifelineScenesParam() {
return createConfigParamMap(10, "LifeLine Scenes", 1, null, null, 63) // Send all scenes to lifeline group.
private getToggleModeParam() {
def val = 15 // Enable for all assocation groups
if (doubleSwipeEnabledSetting) {
val = 0 // Disable for all groups.
return createConfigParamMap(12, "Toggle Mode", 1, null, null, val)
private getParamStoredIntVal(param) {
return state["configVal${param.num}"]
private getParamIntVal(param) {
return param.options ? convertOptionSettingToInt(param.options, param.val) : param.val
private createConfigParamMap(num, name, size, options, prefName, val=null) {
if (val == null) {
val = (settings?."${prefName}" ?: findDefaultOptionName(options))
return [
num: num,
options: options,
prefName: prefName,
val: val
private getGestures() {
def gestures = [
[name: "Swipe Up", sceneNum: 1, keyAttr:0, btnNum: 1, simple: true],
[name: "Swipe Down", sceneNum: 2, keyAttr:0, btnNum: 2, simple: true],
[name: "Swipe Left", sceneNum: 3, keyAttr:0, btnNum: 3, simple: true],
[name: "Swipe Right", sceneNum: 4, keyAttr:0, btnNum: 4, simple: true],
[name: "Clockwise Circle Start", sceneNum: 5, keyAttr: 2, btnNum: 5],
[name: "Clockwise Circle Stop", sceneNum: 5, keyAttr: 1, btnNum: 6],
[name: "Counter-Clockwise Circle Start", sceneNum: 6, keyAttr: 2, btnNum: 7],
[name: "Counter-Clockwise Circle Stop", sceneNum: 6, keyAttr: 1, btnNum: 8],
[name: "Double Swipe Up", sceneNum: 1, keyAttr:3, btnNum: 9],
[name: "Double Swipe Down", sceneNum: 2, keyAttr:3, btnNum: 10],
[name: "Double Swipe Left", sceneNum: 3, keyAttr:3, btnNum: 11],
[name: "Double Swipe Right", sceneNum: 4, keyAttr:3, btnNum: 12]
gestures += sequences
return gestures
private getSequences() {
def items = []
(1..6).each {
items << [
seqNum: it,
sceneNum: (it + 6),
keyAttr: 0,
btnNum: (it + 12)
return items
// Settings
private getCheckinIntervalSettingSeconds() {
return convertOptionSettingToInt(checkinIntervalOptions, checkinIntervalSetting)
private getCheckinIntervalSetting() {
return settings?.wakeUpInterval ?: findDefaultOptionName(checkinIntervalOptions)
private getBatteryReportingIntervalSetting() {
return settings?.batteryReportingInterval ?: findDefaultOptionName(checkinIntervalOptions)
private getDoubleSwipeEnabledSetting() {
return (settings?.doubleSwipeEnabled != null) ? settings?.doubleSwipeEnabled : true
private getBuzzerSetting() {
return (settings?.buzzer != null) ? settings?.buzzer : findDefaultOptionName(buzzerOptions)
private getDebugOutputSetting() {
return (settings?.debugOutput != null) ? settings?.debugOutput : true
private getBtnLabelSetting(btnNum) {
def name = "btn${btnNum}Label"
return (settings && settings[name] != null) ? settings[name] : ""
private getSeqSetting(seqNum) {
def name = "seq${seqNum}"
private getSeqOptions() {
def options = ["": 0]
def simpleGests = gestures.findAll { it.simple }?.each { it.name = it.name.replace("Swipe ", "") }
simpleGests.each { gest1 ->
simpleGests.each { gest2 ->
if (gest1 != gest2) {
options << getSeqOption(gest1, gest2, null)
simpleGests.each { gest3 ->
if (gest1 != gest2 && gest2 != gest3) {
options << getSeqOption(gest1, gest2, gest3)
return options.sort()
private getSeqOption(gest1, gest2, gest3) {
def name = "${gest1.name} / ${gest2.name}"
if (gest3) {
name = "${name} / ${gest3.name}"
def val = ((gest1.btnNum * 256) + (gest2.btnNum * 16) + (gest3?.btnNum ?: 0))
return ["${name}":val]
private getBuzzerOptions() {
return [
"Disabled": 0,
"Successful Recognition": 1,
"Failed Recognition": 2,
"All Recognition${defaultOptionSuffix}": 3
private getCheckinIntervalOptions() {
return getIntervalOptions((2 * 60 * 60), [min:(5 * 60), max:(18*60*60)])
private getIntervalOptions(defaultVal=null, data=[:]) {
def options = [:]
def min = data?.zeroName ? 0 : (data?.min != null ? data.min : 1)
def max = data?.max != null ? data?.max : (9 * 60 * 60)
[0,1,2,3,4,5,10,15,30,45].each {
if (withinRange(it, min, max)) {
if (it == 0 && data?.zeroName != null) {
options["${data?.zeroName}"] = it
else {
options["${it} Second${x == 1 ? '' : 's'}"] = it
[1,2,3,4,5,10,15,30,45].each {
if (withinRange((it * 60), min, max)) {
options["${it} Minute${x == 1 ? '' : 's'}"] = (it * 60)
[1,2,3,6,9,12,18].each {
if (withinRange((it * 60 * 60), min, max)) {
options["${it} Hour${x == 1 ? '' : 's'}"] = (it * 60 * 60)
return setDefaultOption(options, defaultVal)
private withinRange(val, min, max) {
return ((min == null || val >= min) && (max == null || val <= max))
private convertOptionSettingToInt(options, settingVal) {
return safeToInt(options?.find { name, val -> "${settingVal}" == name }?.value, 0)
private setDefaultOption(options, defaultVal) {
def name = options.find { key, val -> val == defaultVal }?.key
if (name != null) {
return changeOptionName(options, defaultVal, "${name}${defaultOptionSuffix}")
else {
return options
private changeOptionName(options, optionVal, newName) {
def result = [:]
options?.each { name, val ->
if (val == optionVal) {
name = "${newName}"
result["${name}"] = val
return result
private findDefaultOptionName(options) {
def option = options?.find { name, val ->
name?.contains("${defaultOptionSuffix}")
return option?.key ?: ""
private getDefaultOptionSuffix() {
return " (Default)"
private logForceWakeupMessage(msg) {
logDebug "${msg} You can force the device to wake up by holding your hand in front of the screen until it enters the menu and then swiping up."
private safeToInt(val, defaultVal=0) {
return "${val}"?.isInteger() ? "${val}".toInteger() : defaultVal
private createEventMap(name, value, displayed=null, desc=null, unit=null) {
def newVal = "${value}"
def isStateChange = displayed ?: (getAttrValue(name) != newVal)
displayed = (displayed == null ? isStateChange : displayed)
def eventMap = [
value: value,
displayed: displayed
if (desc) {
eventMap.descriptionText = desc
logDebug "$desc"
if (unit) {
eventMap.unit = unit
// logTrace "Creating Event: ${eventMap}"
return eventMap
private getAttrValue(attrName) {
try {
return device?.currentValue("${attrName}")
catch (ex) {
logTrace "$ex"
return null
private convertToLocalTimeString(dt) {
def timeZoneId = location?.timeZone?.ID
if (timeZoneId) {
return dt.format("MM/dd/yyyy hh:mm:ss a", TimeZone.getTimeZone(timeZoneId))
else {
return "$dt"
private isDuplicateCommand(lastExecuted, allowedMil) {
!lastExecuted ? false : (lastExecuted + allowedMil > new Date().time)
private logDebug(msg) {
if (debugOutputSetting) {
log.debug "$msg"
private logTrace(msg) {
// log.trace "$msg"
