Folks,
Need some help. I wired the Smart Implant Output 1 and Output 2 in parallel with the wall momentary switches to the garage door opener. The plan is to have the wall switches and the Fibaro open and close the doors. All is well, the problem is when I trigger the Fibaro output it stays in the closed position, therefore nullifying the trigger from the wall switch.
The workaround is to command the garage door from the device menu itself. I have to tell the switch to turn on (garage door triggers) and then I have to tell the switch to be off (normally open contact) to allow the wall switch to work. Is there a way I can make this momentary on then off for let's say 1 second? I did set the switches to "Monophasic" but I have no options for time control. Do I have to create a rule for the dashboard with a virtual button for this to work? Again, everything works, it's just when I trigger the Fibaro output switch, it stays in the "on" or closed, contacts engaged position.
