Fibaro - safe to purchase?
I'm waiting for the new version 1.2.4 before I declare my Aeotec Door/Window Sensors GEN5 a lost cause - but if that proves to be the case am I safe to replace all my sensors (contact and motion) with the latest Fibaro Z-Wave models.
Z-Wave Fibaro Universal Door & Window Sensor 2
Z-Wave Fibaro Motion Sensor
Also I have some Aeotec Range Extender 6, Z-Wave Plus repeater - should I replace those as well ?
Dave
I've had nothing but issues with my z-wave going down. I've removed my fibro double switch and I've had nearly 2 weeks with no issues
Also I could never get my fibro motion sensor working well when I tried moving it from ST
Oh dear - what to do what to do :frowning:
Difficult to find a reliable setup these days.
Just my experience, the double switch was the first device I ever moved over and on the surface all looked good, 12 months later I'm moving all devices over to zigbee (to fix z-wave)gradually but I think I've found the culprit, might have been a dodgy switch
I bought a Fibaro eTRV to try out - paired but was not working properly - Fibaro have firmware updates for this device - but you need to purchase a Fibaro hub to update..... This device is now sitting in my "drawer of shame".
So Not Fibaro, Not Aeotec - maybe I should just stay with ST - this is getting a bit silly not to mention expensive.
As you said at the beginning, wait for 2.2.4 - that's what I'm doing on a lot of Z-Wave stuff that is unreliable at the moment.
I've got 4 of the Fibaro Motion Sensors installed on my HE C-7 hub and they work great. I moved these over to Hubitat from SmartThings with no issues. The battery life on these sensors is great, too.
Encouraging news. Now all I need is confirmation about their door sensors.
Do you use any z-wave repeater/boosters. I doubt my sensors will be USB powered so I assume they wont act as repeaters.
Dave
They are end devices, and do not repeat. You need mains powered repeaters in place if you don't have them. If you're having Z-Wave stability, response or speed issues, that is the first place to start.
I do have 2 x Aeotec Plug In devices but I'm not taking anything for granted when it comes to Habitat compatibility at the moment. Fibaro are expensive and if I'm going to spend a lot of cash on their kit I really want to be as confident as possible it will work out.
Dave
Best to wait as recommended. I'm using very old Aeotec HEM devices as an example. They are very stable and responsive under the current beta. Although I cannot respond directly to the device you are experiencing issues with, ensuring you have an adequate number of repeating devices and patience is important in this regard. :v:
I have about 40 devices on my Z-Wave network and one is a Aeotec repeater, so not a huge network. Interestingly, only one device seems to be routing through the repeater. Go figure.
How do you determine this - love to know.
Dave
Go to Settings -> Z-Wave Details and look at the "Route" column to see the route for each device.
