Hello,
i have this problem with Fibaro rgbw controller. When i connect it with hubitat it recognises it as Zooz (is that suppose to be okay?) i changed it to fibaro one, but dimmer color+white componeents stay as zooz. The first problem is when i put that into dashboard as a color bulb. if change desired colors it freezes, so i ca only go back out and get back in to work with it. After that i tried to make a scene. The first time when light were already on, they turned off at correct time. The next day they didnt turn back on. I ask you guys if someone can help me or direct me to the maybe some fix if i am doing something wrong?
