I am after some assistance or a return of the Hubitat, as a week in and not a single sensor will work with the Hubitat system and have spend hours trying to get anything to work
No Support for Fibaro Dimmer version 1
The Aeon Multi Sensor doesn't update with correct states when they happen but about 20 seconds after
Fibaro double relay doesn't initialise with Hubitat even after 3 resets of Zwave
Fibaro double relay doesn't update correct states in Hubitat and always show as off
Fibaro double relay doesn't turn on or off without sending commands 4 or 5 times.
All of these sensors worked perfectly before my HC2 died and i borrowed a friends to make sure and 15 min later i had them working perfectly again.
I am very frustrated at the moment because i read a lot of great things about Hubitat but it feels very Alpha
Fibaro Double Relay isn't supported officially by Hubitat and custom driver doesn't work as well.
Trying to get work my FGS-222 also, but with no luck still..
if it happens you have the Multisensor 6, there are a LOT of drivers to be found.
I tried to help out by putting a good one in this github... I also altered the name fractionally to make it clearer that it's different from every other copy of the driver. Aeotec vs aeon
Yeah i managed to get the FGS-221 to work with custom commands for rule maker but the 4 in 1 sensor is doing my head in. Temp updates no dramas but no motion and then next thing the sensor goes offline for 4 hours and then works again.
