Is anyone else using the Fibaro Double Smart Module FGS-224 and had issues with them sticking on. I've had the same issue with the older Fibaro Double Switch 2 FGS-223.
I seem to get a few months with no problems and then one morning I'll find that my light that should have turned off, has remained on. The Q1 output remains switched to the line voltage terminal even when powered down. I can hear a slight click from the module when switched on/off but the voltage remains present at Q1. Factory resetting has no effect.
I've a similar setup elsewhere in the house (FGS-224 switching a power supply that is connected to 12V LED strip) without issue. The wiring is fine and I wonder whether I'm just unlucky with this one device. All of my dimmer modules, switches etc are Fibaro and I'd rather not use something different but I'm sick of swapping this one out. Any ideas?
