New convert from smartthings and i've finally moved all but one of my devices over to HE. However i'm having an issue with my fibaro dimmer 2.
If i turn it on via the wall toggle switch, the lights turn on, but it doesn't seem to ever update the dashboard or the device page to state that it's on (it does update if i click refresh on the device page).
This is causing me an issue as it's my bathroom lights and i want it to trigger a fibaro double switch to turn on my bathroom fan. The annoying thing is it worked with smartthings (all be it with a 10 odd second delay).
Could someone please point me in the right direction to try and resolve this.
Sorry, yes i am using the stock driver i don't have another driver for the dimmer installed either.
If i use the dashboard to turn it on, it updates straight away, just not when using the toggle switch on the wall.
have i naffed up the pairing? I did take it out of the loft and bring it into the same room as the hub when i moved it accross. Or can i use a motion sensor to force a refresh of the dimmer?
EDIT: Just tried mine that is installed in the bathroom. It came on with motion and the dashboard updated. I have a pull switch which when pulled to turn light on and off, the dashboard responded correctly so it looks like mine is working OK.
Mine is also set as a toggle switch.
Not sure what to suggest.
I've had this on the hub for some time and I'm fairly sure I had it using a custom driver before the 'In House' one was available.
Trouble is I have 3 and I'm not sure which one I used. I can PM all 3 to you if you want and give them a try. I would try on mine but I'm loathed to do it in case things screw up.
Want me to send them?
That's interesting and this has jogged my solitary brain cell.
I believe all zwave devices used to join using secure inclusion but then HE changed things so that only locks did. They then encouraged people to change to insecure joining apart from locks which I did.
As long as you have it working is all that matters.
Yep as usual the problem was in front of the screen. lol
Now all i need to do is move my ST presence sensors over and then see if there's a way to connect my hive heating to hubitat and i'll be able to turn the ST hub off.
