Hi,
Having some issues with the FGD-212 v3.5 integration.
After connecting it as a momentary switch, in 3-wire connection setup the wall switch worked fine before connecting to hubitat hub c-5. I was able to turn light on / off and dim with wall switch.
After pairing with hubitat hub, the wall switch seems to be inverted. When pressing the momentary switch it turns the light off. When releasing the switch it turns it back on.
I have changed to "momentary switch" in the setup in hubitat config.
Has anybody seen this issue before?
Thanks.
