Here is the modified code that does load into the Hubitat drivers area.
I do not have one so do not know if it works or not.
Give it a try and see if it works OK.
* FIBARO CO Sensor
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "Fibaro CO Sensor ZW5", namespace: "FibarGroup", author: "Fibar Group") {
capability "Carbon Monoxide Detector"
capability "Tamper Alert"
capability "Temperature Measurement"
capability "Configuration"
capability "Battery"
capability "Sensor"
capability "Health Check"
attribute "temperatureAlarm", "string"
attribute "coLevel", "number"
fingerprint mfr: "010F", prod: "1201"
fingerprint deviceId: "0x0701", inClusters:"0x5E,0x59,0x73,0x80,0x22,0x56,0x31,0x98,0x7A,0x5A,0x85,0x84,0x71,0x70,0x8E,0x9C,0x86,0x72"
fingerprint deviceId: "0x0701", inClusters:"0x5E,0x59,0x73,0x80,0x22,0x56,0x31,0x7A,0x5A,0x85,0x84,0x71,0x70,0x8E,0x9C,0x86,0x72"
tiles (scale: 2) {
multiAttributeTile(name:"FGDW", type:"lighting", width:6, height:4) {
tileAttribute("device.carbonMonoxide", key:"PRIMARY_CONTROL") {
attributeState("clear", label:"clear", icon:"https://s3-eu-west-1.amazonaws.com/fibaro-smartthings/coSensor/device_co_1.png", backgroundColor:"#ffffff")
attributeState("detected", label:"detected", icon:"https://s3-eu-west-1.amazonaws.com/fibaro-smartthings/coSensor/device_co_3.png", backgroundColor:"#e86d13")
attributeState("tested", label:"tested", icon:"https://s3-eu-west-1.amazonaws.com/fibaro-smartthings/coSensor/device_co_2.png", backgroundColor:"#e86d13")
tileAttribute("device.multiStatus", key:"SECONDARY_CONTROL") {
attributeState("multiStatus", label:'${currentValue}')
valueTile("coLevel", "device.coLevel", inactiveLabel: false, width: 2, height: 2, decoration: "flat") {
state "coLevel", label:'${currentValue}\nppm', unit:"ppm"
valueTile("temperature", "device.temperature", inactiveLabel: false, width: 2, height: 2) {
state "temperature", label:'${currentValue}°',
backgroundColors:[
[value: 31, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 95, color: "#d04e00"],
[value: 96, color: "#bc2323"]
valueTile("battery", "device.battery", inactiveLabel: false, width: 2, height: 2, decoration: "flat") {
state "battery", label:'${currentValue}%\n battery', unit:"%"
standardTile("temperatureAlarm", "device.temperatureAlarm", inactiveLabel: false, width: 3, height: 2, decoration: "flat") {
state "default", label: "No temp. alarm", backgroundColor:"#ffffff"
state "clear", label:'', backgroundColor:"#ffffff" , icon: "https://s3-eu-west-1.amazonaws.com/fibaro-smartthings/coSensor/heat_detector0.png"
state "overheat", label:'Overheat', backgroundColor:"#d04e00", icon: "https://s3-eu-west-1.amazonaws.com/fibaro-smartthings/coSensor/heat_detector1.png"
standardTile("tamper", "device.tamper", inactiveLabel: false, width: 3, height: 2, decoration: "flat") {
state "clear", label:'', icon: "https://s3-eu-west-1.amazonaws.com/fibaro-smartthings/coSensor/tamper_detector0.png"
state "detected", label:'', icon: "https://s3-eu-west-1.amazonaws.com/fibaro-smartthings/coSensor/tamper_detector100.png"
main "FGDW"
details(["FGDW","coLevel","temperature","battery","temperatureAlarm","tamper"])
preferences {
input (
title: "Fibaro CO Sensor ZW5 manual",
description: "Tap to view the manual.",
image: "http://manuals.fibaro.com/wp-content/uploads/2017/07/co_icon.png",
url: "http://manuals.fibaro.com/content/manuals/en/FGCD-001/FGCD-001-EN-T-v1.1.pdf",
type: "href",
element: "href"
parameterMap().findAll{(it.num as Integer) != 54}.each {
input (
title: "${it.num}. ${it.title}",
description: it.descr,
type: "paragraph",
element: "paragraph"
input (
title: null,
description: "Default: $it.def" ,
type: it.type,
options: it.options,
range: (it.min != null && it.max != null) ? "${it.min}..${it.max}" : null,
defaultValue: it.def,
required: false
input ( name: "logging", title: "Logging", type: "boolean", required: false )
def updated() {
if ( state.lastUpdated && (now() - state.lastUpdated) < 500 ) return
logging("${device.displayName} - Executing updated()","info")
sendEvent(name: "checkInterval", value: 86520, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID])
if ( (settings.zwaveNotifications as Integer) >= 2 ) {
sendEvent(name: "temperatureAlarm", value: "clear", displayed: false)
} else {
sendEvent(name: "temperatureAlarm", value: null, displayed: false)
syncStart()
state.lastUpdated = now()
def configure() {
def cmds = []
sendEvent(name: "coLevel", unit: "ppm", value: 0, displayed: true)
cmds << zwave.batteryV1.batteryGet()
cmds << zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 1)
cmds << zwave.wakeUpV1.wakeUpNoMoreInformation()
encapSequence(cmds,1000)
private syncStart() {
boolean syncNeeded = false
parameterMap().each {
if(settings."$it.key" != null || it.num == 54) {
if (state."$it.key" == null) { state."$it.key" = [value: null, state: "synced"] }
if (state."$it.key".value != (settings."$it.key" as Integer) || state."$it.key".state != "synced" ) {
state."$it.key".value = (settings."$it.key" as Integer)
state."$it.key".state = "notSynced"
syncNeeded = true
if ( syncNeeded ) {
logging("${device.displayName} - sync needed.", "info")
multiStatusEvent("Sync pending. Please wake up the device by pressing the Test button.", true)
private syncNext() {
logging("${device.displayName} - Executing syncNext()","info")
def cmds = []
for ( param in parameterMap() ) {
if ( state."$param.key"?.value != null && state."$param.key"?.state in ["notSynced","inProgress"] ) {
multiStatusEvent("Sync in progress. (param: ${param.num})", true)
state."$param.key"?.state = "inProgress"
cmds << response(encap(zwave.configurationV2.configurationSet(configurationValue: intToParam(state."$param.key".value, param.size), parameterNumber: param.num, size: param.size)))
cmds << response(encap(zwave.configurationV2.configurationGet(parameterNumber: param.num)))
break
if (cmds) {
runIn(10, "syncCheck")
sendHubCommand(cmds,1000)
} else {
runIn(1, "syncCheck")
private syncCheck() {
logging("${device.displayName} - Executing syncCheck()","info")
def failed = []
def incorrect = []
def notSynced = []
if (state."$it.key"?.state == "incorrect" ) {
incorrect << it
} else if ( state."$it.key"?.state == "failed" ) {
failed << it
} else if ( state."$it.key"?.state in ["inProgress","notSynced"] ) {
notSynced << it
if (failed) {
multiStatusEvent("Sync failed! Verify parameter: ${failed[0].num}", true, true)
} else if (incorrect) {
multiStatusEvent("Sync mismatch! Verify parameter: ${incorrect[0].num}", true, true)
} else if (notSynced) {
multiStatusEvent("Sync incomplete! Wake up the device again by pressing the tamper button.", true, true)
} else {
sendHubCommand(response(encap(zwave.wakeUpV1.wakeUpNoMoreInformation())))
if (device.currentValue("multiStatus")?.contains("Sync")) { multiStatusEvent("Sync OK.", true, true) }
private multiStatusEvent(String statusValue, boolean force = false, boolean display = false) {
if (!device.currentValue("multiStatus")?.contains("Sync") || device.currentValue("multiStatus") == "Sync OK." || force) {
sendEvent(name: "multiStatus", value: statusValue, descriptionText: statusValue, displayed: display)
def zwaveEvent(hubitat.zwave.commands.wakeupv2.WakeUpNotification cmd) {
logging("${device.displayName} woke up", "info")
def cmds = []
sendEvent(descriptionText: "$device.displayName woke up", isStateChange: true)
cmds << zwave.sensorMultilevelV5.sensorMultilevelGet()
runIn(1,"syncNext")
[response(encapSequence(cmds,1000))]
def zwaveEvent(hubitat.zwave.commands.configurationv2.ConfigurationReport cmd) {
def paramKey = parameterMap().find( {it.num == cmd.parameterNumber } ).key
logging("${device.displayName} - Parameter ${paramKey} value is ${cmd.scaledConfigurationValue} expected " + state."$paramKey".value, "info")
state."$paramKey".state = (state."$paramKey".value == cmd.scaledConfigurationValue) ? "synced" : "incorrect"
syncNext()
def zwaveEvent(hubitat.zwave.commands.applicationstatusv1.ApplicationRejectedRequest cmd) {
logging("${device.displayName} - rejected request!","warn")
if ( state."$param.key"?.state == "inProgress" ) {
state."$param.key"?.state = "failed"
break
def zwaveEvent(hubitat.zwave.commands.alarmv2.AlarmReport cmd) {
logging("${device.displayName} - AlarmReport received, zwaveAlarmType: ${cmd.zwaveAlarmType}, zwaveAlarmEvent: ${cmd.zwaveAlarmEvent}", "info")
def lastTime = new Date().format("yyyy MMM dd EEE h:mm:ss a", location.timeZone)
switch (cmd.zwaveAlarmType) {
case 2:
switch (cmd.zwaveAlarmEvent) {
case 0:
sendEvent(name: "carbonMonoxide", value: "clear");
multiStatusEvent("CO Clear - $lastTime");
break;
case 2:
sendEvent(name: "carbonMonoxide", value: "detected");
multiStatusEvent("CO Detected - $lastTime");
break;
case 3:
if ( cmd.numberOfEventParameters == 0 ) {
sendEvent(name: "carbonMonoxide", value: "tested");
multiStatusEvent("CO Tested - $lastTime");
} else if (cmd.numberOfEventParameters == 1 && cmd.eventParameter == [1]) {
multiStatusEvent("CO Test OK - $lastTime");
break;
break;
case 7:
sendEvent(name: "tamper", value: (cmd.zwaveAlarmEvent == 3)? "detected":"clear");
if (cmd.zwaveAlarmEvent == 3) { multiStatusEvent("Tamper - $lastTime") }
break;
case 4:
if (device.currentValue("temperatureAlarm")?.value != null) {
case 0: sendEvent(name: "temperatureAlarm", value: "clear"); break;
case 2: sendEvent(name: "temperatureAlarm", value: "overheat"); break;
break;
default: logging("${device.displayName} - Unknown zwaveAlarmType: ${cmd.zwaveAlarmType}","warn");
def zwaveEvent(hubitat.zwave.commands.sensormultilevelv5.SensorMultilevelReport cmd) {
logging("${device.displayName} - SensorMultilevelReport received, sensorType: ${cmd.sensorType}, scaledSensorValue: ${cmd.scaledSensorValue}", "info")
switch (cmd.sensorType) {
case 1:
def cmdScale = cmd.scale == 1 ? "F" : "C"
sendEvent(name: "temperature", unit: getTemperatureScale(), value: convertTemperatureIfNeeded(cmd.scaledSensorValue, cmdScale, cmd.precision), displayed: true)
break
case 40:
sendEvent(name: "coLevel", unit: "ppm", value: cmd.scaledSensorValue, displayed: true)
break
default:
logging("${device.displayName} - Unknown sensorType: ${cmd.sensorType}","warn")
break
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
logging("${device.displayName} - BatteryReport received, value: ${cmd.batteryLevel}", "info")
sendEvent(name: "battery", value: cmd.batteryLevel.toString(), unit: "%", displayed: true)
def result = []
logging("${device.displayName} - Parsing: ${description}")
if (description.startsWith("Err 106")) {
result = createEvent(
descriptionText: "Failed to complete the network security key exchange. If you are unable to receive data from it, you must remove it from your network and add it again.",
eventType: "ALERT",
value: "failed",
displayed: true,
} else if (description == "updated") {
return null
} else {
def cmd = zwave.parse(description, cmdVersions())
if (cmd) {
logging("${device.displayName} - Parsed: ${cmd}")
zwaveEvent(cmd)
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
def encapsulatedCommand = cmd.encapsulatedCommand(cmdVersions())
if (encapsulatedCommand) {
logging("${device.displayName} - Parsed SecurityMessageEncapsulation into: ${encapsulatedCommand}")
zwaveEvent(encapsulatedCommand)
} else {
log.warn "Unable to extract secure cmd from $cmd"
def zwaveEvent(hubitat.zwave.commands.crc16encapv1.Crc16Encap cmd) {
def version = cmdVersions()[cmd.commandClass as Integer]
def ccObj = version ? zwave.commandClass(cmd.commandClass, version) : zwave.commandClass(cmd.commandClass)
def encapsulatedCommand = ccObj?.command(cmd.command)?.parse(cmd.data)
logging("${device.displayName} - Parsed Crc16Encap into: ${encapsulatedCommand}")
} else {
log.warn "Could not extract crc16 command from $cmd"
private logging(text, type = "debug") {
if (settings.logging == "true") {
log."$type" text
private secEncap(hubitat.zwave.Command cmd) {
logging("${device.displayName} - encapsulating command using Secure Encapsulation, command: $cmd","info")
zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
private crcEncap(hubitat.zwave.Command cmd) {
logging("${device.displayName} - encapsulating command using CRC16 Encapsulation, command: $cmd","info")
zwave.crc16EncapV1.crc16Encap().encapsulate(cmd).format()
private encap(hubitat.zwave.Command cmd) {
if (zwaveInfo.zw.contains("s")) {
secEncap(cmd)
} else if (zwaveInfo.cc.contains("56")){
crcEncap(cmd)
} else {
logging("${device.displayName} - no encapsulation supported for command: $cmd","info")
cmd.format()
private encapSequence(cmds, Integer delay=250) {
delayBetween(cmds.collect{ encap(it) }, delay)
private List intToParam(Long value, Integer size = 1) {
def result = []
size.times {
result = result.plus(0, (value & 0xFF) as Short)
value = (value >> 8)
return result
private Map cmdVersions() {
[0x5E: 2, 0x59: 1, 0x73: 1, 0x80: 1, 0x22: 1, 0x56: 1, 0x31: 5, 0x98: 1, 0x7A: 3, 0x5A: 1, 0x85: 2, 0x84: 2, 0x71: 2, 0x70: 2, 0x8E: 2, 0x9C: 1, 0x86: 1, 0x72: 2]
private parameterMap() {[
[key: "zwaveNotifications", num: 2, size: 1, type: "enum", options: [
0: "Both actions disabled",
1: "Tampering (opened casing)",
2: "Exceeding the temperature",
3: "Both actions enabled"
def: "0", title: "Z-Wave notifications",
descr: "This parameter allows to set actions which result in sending notifications to the HUB"],
[key: "highTempTreshold", num: 22, size: 1, type: "enum", options: [
50: "120 °F / 50°C",
55: "130 °F / 55°C",
60: "140 °F / 60 °C",
65: "150 °F / 65 °C",
71: "160 °F / 71 °C",
77: "170 °F / 77 °C",
80: "176 °F / 80 °C"
def: "55", title: "Threshold of exceeding the temperature",
descr: "This parameter defines the temperature level, which exceeding will result in sending actions set in paramater 2."]
