Fibaro Button FGPB-101-1 US z-wave
Platform version 2.4.2.125
Hardware Version Rev C-5
fibaro FGPB-101-1 US Z-Wave button
I had one of these devices working great in Hubitat for quite a while. I stopped working a long time ago, and I assumed the battery was dead. I replaced the battery, and it still did not work. I thought the device had just died or something. Recently, I started looking into this again, and Hubitat showed the device as online. It was not getting any information aside from it being online. Not logs, no history, nothing assigned to the button worked. I tried to exclude and didn't respond. I deleted the button and then tried to re-add it. Tried factory reset and re-add, not showing as a generic Z-Wave device or by using the specific Fibaro FGPB-101-1 US option in devices. The device does not appear at all during inclusion, regardless of what I try.
I recently purchased a new Fibaro button, and it is exhibiting the same behavior. Right out of the box, I cannot get it to pair during inclusion. It does not even show up during the inclusion process. I have read the manuals for the device, and I know you must press it 6 times for inclusion. 4 times to wake up, 5 times plus 5-second hold for factory reset.
It's starting to look more and more like it could be an issue with Hubitat. I've been reading through your support forums but haven't found anything that sounds like my same issue.
Do you have any thoughts or ideas on this issue? Any help would be greatly appreciated.
Thanks!
Are any other z-wave devices working with your C-5?
Yes, I have many Z-Wave devices working
