Hi,
Having many Fibaro 223,
Working grate.
Now I want to add a rule to be called when holding the switch or double tapping on it.
I can do it with Xiaomi button, because when I select a button as trigger I have double tap etc in the rule, but when I am using a switch, I can't select this option and I have only turn On or Turn Off.
How can it be done?
It doesn't look like the fibaro supports the button capability as it is just a switch.
