Fibaro 222 issues after 2.2.1 update
I have 2 x fgs 222 double relays that are not reporting status and one seems to have reset and it is not accepting configure to change the parameters. I can still turn them on/off so zwave is still working, and i have no issues with other zwave devices.
Anyone else having issues? only started after the update 2.2.1
They have been rock solid ever since i installed them until now.
Are you using an in built driver or a community driver?
Community one, there's never been a HE driver released.
Was working since 2018 until now.
You could check to see if their is an update by the dev for the driver. Likely it is the same as the above and you could modify the driver.
Bit of help from @bobbles & @Brandon all sorted with below driver code,
 *	Fibaro FGS-222 Double Relay Switch Device Type - For use on Hubitat
 *	Author: Robin Winbourne
 *	Date: 2018-03-24
metadata {
definition (name: "Fibaro FGS-222 Double Relay Switch", namespace: "hubitat", author: "Robin Winbourne") {
capability "Switch"
capability "Relay Switch"
capability "Polling"
capability "Configuration"
capability "Refresh"
//capability "Zw Multichannel"
attribute "switch1", "string"
attribute "switch2", "string"
command "on1"
command "off1"
command "on2"
command "off2"
command "updateSingleParam" // This custom command can be used with Rule Machine or webCoRE, to send parameter values (paramNr & paramvalue) to the device
fingerprint deviceId: "0x1001", inClusters:"0x86, 0x72, 0x85, 0x60, 0x8E, 0x25, 0x20, 0x70, 0x27"
   preferences {
        input name: "param1", type: "enum", defaultValue: "255", required: true,
            title: "Parameter No. 1 - Activate / deactivate functions ALL ON / ALL OFF. Default value: 255.",
       		options: [
                    ["255" : "255 - ALL ON active, ALL OFF active"],
                    ["0" : "0 - ALL ON is not active ALL OFF is not active"],
                    ["1" : "1 - ALL ON is not active ALL OFF active"],
                    ["2" : "2 - ALL ON active ALL OFF is not active"]
        input name: "param3", type: "enum", defaultValue: "0", required: true,
            title: "Parameter No. 3 - Auto off relay after specified time, with the possibility of manual override - immediate Off after button push. Default value: 0.",
       		options: [
                    ["0" : "0 - Manual override disabled"],
                    ["1" : "1 - Manual override enabled"]
		input name: "param4", type: "number", range: "0..65535", defaultValue: "0", required: true,
            title: "Parameter No. 4 - Auto off for relay 1.  " +
                   "Available settings:\n" +
                   "[1 - 65535] (0,1 s – 6553,5 s) Time period for auto off, in miliseconds,\n" +
                   "0 - Auto off disabled.\n" +
                   "Default value: 0."
		input name: "param5", type: "number", range: "0..65535", defaultValue: "0", required: true,
            title: "Parameter No. 5 - Auto off for relay 2.  " +
                   "Default value: 0."
		input name: "param6", type: "enum", defaultValue: "0", required: true,
            title: "Parameter No. 6 - Sending commands to control devices assigned to 1st association group (key no. 1). " +
                   "NOTE: Parameter 15 value must be set to 1 to work properly. Default value: 0.",
       		options: [
                    ["0" : "0 - Commands are sent when device is turned on and off"],
                    ["1" : "1 - Commands are sent when device is turned off"],
                	["2" : "2 - Commands are sent when device is turned off"]
       		input name: "param7", type: "enum", defaultValue: "0", required: true,
            title: "Parameter No. 7 - Sending commands to control devices assigned to 2nd association group (key no. 2). " +
       		options: [
		input name: "param13", type: "enum", defaultValue: "0", required: true,
            title: "Parameter No. 13 - Assigns bistable key status to the device. Default value: 0.",
       		options: [
                    ["0" : "0 - Device changes status on key status change"],
                    ["1" : "1 - Device status depends on key status: ON when the key is ON"]
		input name: "param14", type: "enum", defaultValue: "1", required: true,
            title: "Parameter No. 14 - Switch type connector, you may choose between momentary and toggle switches. Default value: 1.",
       		options: [
                    ["0" : "0 - Momentary switch"],
                    ["1" : "1 - Toggle switch"]
		input name: "param15", type: "enum", defaultValue: "0", required: true,
            title: "Parameter No. 15 - Operation of the Dimmer and Roller Shutter Controller - enabling this option allows the user to dim lighting/shut roller by associating Dimmer/Roller Shutter Controller and holding or double press of double switch (only mono-stable switch). Default value: 0.",
       		options: [
                    ["0" : "0 - Dimmer/Roller Shutter Controller control is not active"],
                    ["1" : "1 - Dimmer/Roller Shutter Controller control is active"]
		input name: "param16", type: "enum", defaultValue: "1", required: true,
            title: "Parameter No. 16 - Saving the state of the device after a power failure. Default value: 1.",
       		options: [
                    ["0" : "0 - Switch returns to 'off' position"],
                    ["1" : "1 - Switch saves its state before power failure"]
        input name: "param30", type: "enum", defaultValue: "3", required: true,
            title: "Parameter No. 30 - Relay 1 - Response to General Alarm. Default value: 3.",
       		options: [
                    ["0" : "0 - Switch does not respond to alarm"],
                    ["1" : "1 - Switch turns on after detecting an alarm"],
                	["2" : "2 - Switch turns off after detecting an alarm"],
                	["3" : "3 - Switch flashes after detecting an alarm"]
     	input name: "param31", type: "enum", defaultValue: "2", required: true,
            title: "Parameter No. 31 - Relay 1 - Response to Flood Alarm. Default value: 2.",
       		options: [
       input name: "param32", type: "enum", defaultValue: "3", required: true,
            title: "Parameter No. 32 - Relay 1 - Response to Smoke, CO, CO2 Alarm. Default value: 3.",
       		options: [
       input name: "param33", type: "enum", defaultValue: "1", required: true,
            title: "Parameter No. 33 - Relay 1 - Response to Temperature Alarm. Default value: 1.",
       		options: [
    	input name: "param40", type: "enum", defaultValue: "3", required: true,
            title: "Parameter No. 40 - Relay 2 - Response to General Alarm. Default value: 3.",
       		options: [
     	input name: "param41", type: "enum", defaultValue: "2", required: true,
            title: "Parameter No. 41 - Relay 2 - Response to Flood Alarm. Default value: 2.",
       		options: [
       input name: "param42", type: "enum", defaultValue: "3", required: true,
            title: "Parameter No. 42 - Relay 2 - Response to Smoke, CO, CO2 Alarm. Default value: 3.",
       		options: [
       input name: "param43", type: "enum", defaultValue: "1", required: true,
            title: "Parameter No. 43 - Relay 2 - Response to Temperature Alarm. Default value: 1.",
       		options: [
		input name: "param39", type: "number", range: "0..65535", defaultValue: "600", required: true,
            title: "Parameter No. 39 - Active flashing alarm time. " +
            	   "This parameter allows to set time parameter used in timed modes.\n" +
                   "[1-65535][ms].\n" +
                   "Default value: 600."
    input name: "paramAssociationGroup1", type: "bool", defaultValue: true, required: true,
             title: "The Fibaro Sigle Switch provides the association of three groups.\n\n" +
                    "1st group is assigned to key no. 1.\n" +
                    "Default value: true"
        input name: "paramAssociationGroup2", type: "bool", defaultValue: true, required: true,
             title: "2nd group is assigned to key no. 2.\n" +
        input name: "paramAssociationGroup3", type: "bool", defaultValue: false, required: true,
             title: "3rd group reports state of devices. Only one device can be associated to this group.\n" +
                    "Default value: false"
    def result = []
    def cmd = zwave.parse(description)
    if (cmd) {
        result += zwaveEvent(cmd)
        log.debug "Parsed ${cmd} to ${result.inspect()}"
    } else {
        log.debug "Non-parsed event: ${description}"
    return result
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd) {
	sendEvent(name: "switch", value: cmd.value ? "on" : "off", type: "digital")
    def result = []
    result << zwave.multiChannelV4.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:1, commandClass:37, command:2).format()
    result << zwave.multiChannelV4.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:2, commandClass:37, command:2).format()
    response(delayBetween(result, 1000)) // returns the result of reponse()
def zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd)
    def result = []
def zwaveEvent(hubitat.zwave.commands.multichannelv4.MultiChannelCapabilityReport cmd)
    log.debug "multichannelv4.MultiChannelCapabilityReport $cmd"
    if (cmd.endPoint == 2 ) {
        def currstate = device.currentState("switch2").getValue()
        if (currstate == "on")
        	sendEvent(name: "switch2", value: "off", isStateChange: true, display: false)
        else if (currstate == "off")
        	sendEvent(name: "switch2", value: "on", isStateChange: true, display: false)
    else if (cmd.endPoint == 1 ) {
        def currstate = device.currentState("switch1").getValue()
        sendEvent(name: "switch1", value: "off", isStateChange: true, display: false)
        sendEvent(name: "switch1", value: "on", isStateChange: true, display: false)
def zwaveEvent(hubitat.zwave.commands.multichannelv4.MultiChannelCmdEncap cmd) {
   def map = [ name: "switch$cmd.sourceEndPoint" ]
   switch(cmd.commandClass) {
      case 32:
         if (cmd.parameter == [0]) {
            map.value = "off"
         if (cmd.parameter == [255]) {
            map.value = "on"
         createEvent(map)
         break
      case 37:
            map.value = "off"
            map.value = "on"
         break
    def events = [createEvent(map)]
    if (map.value == "on") {
            events += [createEvent([name: "switch", value: "on"])]
    } else {
         def allOff = true
         (1..2).each { n ->
             if (n != cmd.sourceEndPoint) {
                 if (device.currentState("switch${n}").value != "off") allOff = false
         if (allOff) {
             events += [createEvent([name: "switch", value: "off"])]
    events
def zwaveEvent(hubitat.zwave.Command cmd) {
    // This will capture any commands not handled by other instances of zwaveEvent
    // and is recommended for development so you can see every command the device sends
    return createEvent(descriptionText: "${device.displayName}: ${cmd}")
def zwaveEvent(hubitat.zwave.commands.switchallv1.SwitchAllReport cmd) {
   log.debug "SwitchAllReport $cmd"
def refresh() {
	def cmds = []
    cmds << zwave.manufacturerSpecificV2.manufacturerSpecificGet().format()
	cmds << zwave.multiChannelV4.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:1, commandClass:37, command:2).format()
    cmds << zwave.multiChannelV4.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:2, commandClass:37, command:2).format()
	delayBetween(cmds, 1000)
def zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
	def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
	log.debug "msr: $msr"
    updateDataValue("MSR", msr)
def poll() {
	def cmds = []
def configure() {
	log.debug "Executing 'configure'"
    delayBetween([
          zwave.configurationV1.configurationSet(parameterNumber:1, configurationValue:[param1.value]).format(),
          zwave.configurationV1.configurationSet(parameterNumber:3, configurationValue:[param3.value]).format(),
          zwave.configurationV1.configurationSet(parameterNumber:4, configurationValue:[param4.value]).format(),
          zwave.configurationV1.configurationSet(parameterNumber:5, configurationValue:[param5.value]).format(),
          zwave.configurationV1.configurationSet(parameterNumber:6, configurationValue:[param6.value]).format(),
          zwave.configurationV1.configurationSet(parameterNumber:7, configurationValue:[param7.value]).format(),
          zwave.configurationV1.configurationSet(parameterNumber:13, configurationValue:[param13.value]).format(),
          zwave.configurationV1.configurationSet(parameterNumber:14, configurationValue:[param14.value]).format(),
          zwave.configurationV1.configurationSet(parameterNumber:15, configurationValue:[param15.value]).format(),
          zwave.configurationV1.configurationSet(parameterNumber:16, configurationValue:[param16.value]).format(),
          zwave.configurationV1.configurationSet(parameterNumber:30, configurationValue:[param30.value]).format(),
          zwave.configurationV1.configurationSet(parameterNumber:31, configurationValue:[param31.value]).format(),
          zwave.configurationV1.configurationSet(parameterNumber:32, configurationValue:[param32.value]).format(),
          zwave.configurationV1.configurationSet(parameterNumber:33, configurationValue:[param33.value]).format(),
          zwave.configurationV1.configurationSet(parameterNumber:39, configurationValue:[param39.value]).format(),
          zwave.configurationV1.configurationSet(parameterNumber:40, configurationValue:[param40.value]).format(),
          zwave.configurationV1.configurationSet(parameterNumber:41, configurationValue:[param41.value]).format(),
          zwave.configurationV1.configurationSet(parameterNumber:42, configurationValue:[param42.value]).format(),
          zwave.configurationV1.configurationSet(parameterNumber:43, configurationValue:[param43.value]).format(),
          zwave.associationV2.associationSet(groupingIdentifier:1, nodeId:[zwaveHubNodeId]).format(),
          zwave.associationV2.associationSet(groupingIdentifier:2, nodeId:[zwaveHubNodeId]).format(),
          zwave.associationV2.associationSet(groupingIdentifier:3, nodeId:[zwaveHubNodeId]).format(),
def updateSingleparam(paramNum, paramValue) {
	log.debug "Updating single Parameter (paramNum: $paramNum, paramValue: $paramValue)"
    	zwave.configurationV1.configurationSet(parameterNumber: paramNum, ConfigurationValue: paramValue)
* Triggered when Save button is pushed on Preference UI
def updated()
	log.debug "Preferences have been changed. Attempting configure()"
    def cmds = configure()
    response(cmds)
def on() {
   delayBetween([
        zwave.switchAllV1.switchAllOn().format(),
        zwave.multiChannelV4.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:1, commandClass:37, command:2).format(),
    ], 500)
def off() {
   delayBetween([
        zwave.switchAllV1.switchAllOff().format(),
    ], 500)
def on1() {
    delayBetween([
        zwave.multiChannelV4.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:1, commandClass:37, command:1, parameter:[255]).format(),
    ], 500)
def off1() {
    delayBetween([
        zwave.multiChannelV4.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:1, commandClass:37, command:1, parameter:[0]).format(),
    ], 500)
def on2() {
    delayBetween([
        zwave.multiChannelV4.multiChannelCmdEncap(sourceEndPoint:2, destinationEndPoint:2, commandClass:37, command:1, parameter:[255]).format(),
        zwave.multiChannelV4.multiChannelCmdEncap(sourceEndPoint:2, destinationEndPoint:2, commandClass:37, command:2).format()
    ], 500)
def off2() {
    delayBetween([
        zwave.multiChannelV4.multiChannelCmdEncap(sourceEndPoint:2, destinationEndPoint:2, commandClass:37, command:1, parameter:[0]).format(),
    ], 500)
Same for me. Changed the code as advised here from V3 to V4 and still it did not work (now the problem was not being able to turn the switch off and the light went off automatically after 30 seconds).
Excluded the Z-wave and did not have the chance to include again.
Did it work for you?
Did you paste all the code from my post above? I tried to do it manually at first via find and replace but it didn't work! I had to paste the code above replacing all the original driver code then it worked.
Ended up deleting the device, reseting it and including it again and it works now.
Yeah that would of been my next step, just pain building back into the rules etc. Glad you got it sorted anyway.
