Chrome 124.0.6367.209 (Official Build) (64-bit) on Windows 10
Just a list of random observations.
- Sometimes, when creating a copy of a tile (via the gear icon/checkbox), the copy will be placed in the upper left of the dashboard, covering the tile that is already there.
- If you have changed the size of a tile, when editing its settings, its size may revert to the dashboard default. (I think this happens when changing the "show" menu option.) This sucks because it can force a cascade of placement changes.
- The dashboard will occasionally go entirely blank for a moment and re-draw itself.
- This can happen while editing tile settings, in which case it forcibly closes the dialog and you lose your changes.
- This can happen while a tile is being moved, which forces it back to its starting point.
- Often, when dragging a tile, the tile will snap back to where it was instead of dropping into the highlighted spot.
- Sometimes, when trying to resize a tile, it ends up moving instead of changing size even if you were definitely clicking the right corner.
