A couple things on Easy Dashboard. First is with my door lock. On the old dashboard, when you click the tile, a popup asks are you sure you want to unlock the door. Easy Dashboard doesn't have that. Not sure if that was meant to be left out, but if so, there needs to be the option then to have it.
Secondly it text. The status is in lower case. Example - if a light is on or off, it says on instead of On. Also, things that have a battery show a battery indicator, but that covers part of the status. On buttons, I get about two characters of the label, but the button takes up a large area of the tile, with just a label that says B1.
Another problem is a tile I have for a hygrometer outside. I have to make it 4 spaces in size to show both temp and humidity. If I make it smaller, and only show one, it just shows a number, not label if that's temp or %.
