Feature Request: Virtual valve
we’ve got virtual devices for most everything else, I’d like a virtual valve too. I have a NC solenoid connected to a switch that I want to show up as a valve everywhere. I’d like to map the valve to the switch with RM and have it show up as a valve in homebridge.
thanks
Here you go:
// Copyright 2016, 2017, 2018, 2019 Hubitat Inc.  All Rights Reserved
metadata {
    definition (name: "Virtual Valve", namespace: "hubitat", author: "Mike Maxwell") {
        capability "Valve"
    preferences {
        input name: "txtEnable", type: "bool", title: "Enable descriptionText logging", defaultValue: true
def installed() {
    log.warn "installed..."
    close()
def updated() {
    log.info "updated..."
    log.warn "description logging is: ${txtEnable == true}"
def open() {
    def descriptionText = "${device.displayName} was opened"
    if (txtEnable) log.info "${descriptionText}"
    sendEvent(name: "valve", value: "open", descriptionText: descriptionText)
def close() {
    def descriptionText = "${device.displayName} was closed"
    sendEvent(name: "valve", value: "closed", descriptionText: descriptionText)
Perfect! Thanks
