I love the functionality of the Thermostat Controller app, but I've run into an issue. I'm using it to control an inverter heat pump and some of the functions don't work great for that.
The inverter heat pump unit is designed to intelligently adjust the heating and cooling output based on the room temperature and setpoint. That's where much of the efficiency comes from. Unfortunately, the unit's thermostat doesn't automatically change between heating/cooling modes. I like in Oklahoma and we often have days that require heating in the early morning and cooling in the evening. So, I was hoping to use the Thermostat Scheduler app in conjunction with the Controller app to automatically switch between modes and set the setpoints automatically. But, the Thermostat Controller app has the "control offset" which causes the unit to turn off completely instead of ramp down and stay on at a low level when it satisfies the setpoint.
In case I'm not explaining this well, here's basically what I'm hoping to accomplish:
Settings:
Cool Setpoint: 74
Heat Setpoint: 69
Functionality:
When room temp rises above 74 degrees, the unit is set to cool mode and the cool setpoint is set to 74. When the room temp falls below 69 degrees, the unit is set to heat mode and the heat setpoint is set to 69. That's it. No adjusting the setpoint unless the temperature crosses the opposite setpoint.
So, basically I think I'm asking for the ability to disable the "control offset" so that the Thermostat Controller app doesn't adjust the set points and doesn't "idle" the unit.
Thanks for considering this!
