I know that systemStart events are already logged in System Events > Hub Events. It would be nice if a one-line entry was put into the "Current logs" / "Past logs", even identical to the line that appears in Hub Events. For that matter, it would be nice if a one-line entry was put into Hub Events for shutdown, and also in Past logs.
By scrolling through the Past logs, I can infer when these events happened because, for example, the Lutron telnet connection gets re-established, etc., on startup. But it would be nice if a simple entry were to be put in the logs.
Obviously, this is low priority and not a necessity. Thanks in advance.
