One step better - set the plug to turn itself back on. I use this plug for that very purpose in my cable-modem network reset routine. It's not available directly from the device page, but if you switch the driver to the basic z-wave tool, you can set param 41 to 10 (size is 1 byte), then however/whenever the switch it turned off, it will turn itself back on after 10 secs. You can set number of seconds to your choosing. Then switch back to the normal device driver.
See attached PDF manual at the bottom of the link above for details. Configuration parameters start on page 9, param 41 is on pg 16.
As long as you have power, switch comes back on!
If you're not familiar with the basic z-wave tool, it's a custom driver built by @mike.maxwell available from GitHub. Details here:
