Granted, this does require a little bit of custom code, but I just thought I would share in case anyone is interested in how to do this with Rule Machine. I'm not a developer either and do rely on the extreme generosity of the talented developers we are so lucky to have help out and share code on the forum and in their own personal repos. I owe the credit to @ogiewon, @mike.maxwell, and @cwwilson08 for showing me how to do this. It's a simple yet very useful little driver since you can easily modify it to change the state of anything. I added contact sensor just now, but have one that I modified for presence too.
Creating the virtual switches took me about 2 minutes, so that's not too bad considering this is a thing you would do once and then you're done. I labelled them virtual switch just because it was easy since it was already in my browsers autofill cache since I use a lot of virtual switches. Making the rule took around 30 seconds. So not to counter the app. Easier is great, especially when it's essentially handed to us for free.
Since the small custom driver has capabilities defined for switch, motion and contact sensor, the rule can "turn on" in a sense, the motion and contact sensors. This essentially make them available in HSM as a contact sensor or motion sensor that is activated by turning on a switch.
This is the code for it. Note that this is how I do Alexa TTS too. Just turn on this virtual switch, and an Alexa Routine sees it as "motion active" and speaks my custom phrase.
Remember that whenever you have two doors that open against each other, you don’t need to sensors you need one. One has the magnet the other has the sensor. Only time you would need to in that situation is when you need to know specifically which door is open
I tried that, I couldn't get it to trigger 100% with only one sensor. I don't know if it was this particular brand/type sensor, or the spacing of the doors, or what. It was much more reliable, and less fiddling with sensors, with both doors having a separate sensor.
It’s probably either one of those. I’m using a Xiaomi sensor on my fridge which is the style with the top freezer. It is very reliable, but alignment took a little bit of trial and error.
'Average All' will group:
Motion sensors, contacts,switches
Motion.. active if any active, inactive when ALL inactive
Contacts... Open if any open, closed when ALL closed
Switches... On if any on.. off when ALL off
Thanks for this...very useful and much faster than using RuleMachine. Any chance you could add locks to this too? I use this group to change a status RGB to let me know when the house is all locked up properly before arming the alarm for night.
Yeah, same concept as the contacts with unlocked/locked just like open/close. I have 5 z-wave locks that I want to check that all of them are locked just like all of my contact sensors. Or even if they can be grouped up with the contact sensor group would even be better. I have a RGB light that I turn green when all the selected contact sensors and locks are closed/locked. Not a huge problem it its too much trouble just thought it would be nice rather than having RM checking each lock too.
I added a new child grouping for locks, you might want to look at [BETA] Hubitat Package Manager as a means of installing this. As things get more and more child apps, installing it manually gets to be more and more work.
Just another quick idea to layer onto the recent posts above. Another flag that says if all the child apps are positive or negative. This could then be used to provide an overall status for the property (eg. all locks are locked, all contacts are closed, all leak detectors are dry). Use case - I'm building a dashboard where I want an overall status light for the property (green is "everything good", yellow is "something is bad", red is "everything is bad" or something major is bad" etc).
Thank you for considering it! And sorry for the inevitable scope creep as soon as you've put a great app together!
Hmm trying to think of how to do that because it would require creating some kind of device to report that state. I'll think about that more but work on the leak sensor first.
