I would like to use vibration sensors for triggered activation using ZMC but also directly in Room Lights.
My current workaround is to use the built-in mirror app to map the acceleration attribute to a virtual motion sensor.
When these first came out, 3R's instructions for Hubitat setup were to use the Generic Zigbee Motion Sensor driver. I used that until I noticed but long ago that HE made the other driver for it.
The motion sensor driver worked great - no complaints at all.
ETA -- though I don't think it matters either way, I used the ...(no temp) generic motion driver.
Thanks - I'll switch to that, then.
Hopefully it works well for you -- I don't recall any software updates for this thing, so unless newer versions of it are somehow different from earlier production runs, it should work fine. I noticed no difference at all in performance when I switched drivers.
