I use the dashboard quite extensively. One of the tricks I've learned is to stack tiles on top of one another and use background-color transparency to create interesting 'animations', colors and/or to signify the state of something or other beneath a button. The problem is, when doing so, the tiles MUST share the same name or the respective text of the 2+ tiles simply overlaps rendering the tile illegible. I've messed with template foreground color but that affects every instance of that tile type so doesn't really work.
Feature request: provide an 'alias' on a per-tile basis that overrides the natural name of the tile's parent device/variable and also permits the alias to be null.
Thanks for considering!
