Hi everyone
I have just had a Fibaro Multisensor Gen5 fail on me.
Changed the battery and nothing, no lights at all. Reset nothing....
I have contacted Fibaro's Support with no response in 4 days.
So I am seeking a replacement here in Uk
Can anyone recommend a device that will detect motion and report illuminance levels please?
I don't find the Hue all that fast when joined to my Hue bridge but others that have it paired with HE say it's really fast and it reports illuminance. I have the outdoor version paired to HE and it is really fast and illuminance reporting is very good.
Try this. Put a fresh battery in with reverse polarity for about 30 seconds. Then pull it out and put it in the right way. I've brought a few sensors back to life doing that.
I will second this. I love the outdoor model but the indoor has a poor range compared to the Iris V2 sensors I snapped up from Ebay and the motion sensing is a bit slow compared to the outdoor model. Only downside of the Iris is there is no light sensor
Thank you for the comments
I bought the Fibaro for the illuminance as well, so I can determine the ambient light levels, at the front and back of the house.
Then I selectively activate lights based on motion as well as ambeient light levels
So now thinking of purchasing 2x Hue Outdoor Motion sensors to cover front/back of house as well as recording the illuminance
If you have a Hue bridge, there are firmware updates for both indoor and outdoor sensors. I have Iris V2, Hue, and Sylvania motion sensors. I have never had to re-pair any of them and they all have been fast. The indoor Hue can be chatty if it's in a high traffic area, so I wouldn't want bulbs repeating for it. Mine is at the far end of the house on a different floor than the HE and no issues.
Fibaro support came back to me. THey advised me to Reset the sensor (Hold B Button for 5 secs and then on Yellow Press B again). THis brought it back to life...
And BTW this z-wave sensor seems to be pretty quick
I was just thinking of the hardware. If the sensor survives reverse voltage, there must be some protection against putting the battery in backward. Else the electronics would be damaged. So perhaps the reversed battery just brings the capacitors to 0 and allows a better power on reset.
Just a thought.
I would be best to try a short before reversed battery in other devices in case they can't survive the reversed battery.
It only sends motion at the set lux level. This cuts down on battery usage. It has a Red LED to show motion area during setup, then you turn it off, again for battery life. I also got it for the white housing matches my houses gutters.
Can HE take advantage of the room temperature feature of the Hue motion sensors? Iow, can I read the temperature and use that in an automation? E.G. turn the ceiling fan on if motion sensor says > 75 degrees? Thx
