Hi guys! Anyone has experience integrating these cloud devices with hubitat system? I imagine that is doable after I found drivers for MagicHome cloud led controllers here
Sp501e generally is a pretty good controller and I was hoping it is rather popular in community.
No idea But I think in a very similar manner as MagicHome devices. They have FairyNest app, where you have to create an account first and then add your devices to control them. The only difference that I found between FN and MH is that MH saves animations and timings when device is unplugged while FN doesn't. Not sure why, but maybe MH saves that data on the cloud, and FN doesn't? No idea. Even though I am a web-coder I have very low understanding on how this hardware works.
I was hoping I could flash the controllers with some open-source supported software... and I found that it is possible, but only with soldering involved, which is not an option for me. At least not right now.
8285-based 1M Controller that supports both Addressable and PWM-based RGBWW LED strips . 5-24v DC input, 55mm x 26mm, sold under BTF lighting, RGBZone, etc. Vendors all list 'Fairynest' as the supporting mobile application. Board is silk screened with 'SP5XXe' but no other markings. RS232 pads are exposed on the back-side of the board with GND and GPIO0 right next to each other and thus Flash access fairly straight forward. GPIO 0 must be pulled to GND at boot and throughout the flashing process. I/O configuration: LEDPIN is 'GPIO03' for Addressable, BTNPIN is GPIO 1. PWM pin out for RGBWW (UNTESTED): CW: 14, WW: 12, B: 13, R: 02 and G: GPIO04. Flashed via PlatformIO, ESPHome and Tasmotizer. OTA updates untested. Pics of board here: SP501e-RGB-LED-Controller-/SP501e_top_bottom_traced.jpg at master · Operation760/SP501e-RGB-LED-Controller- · GitHub Flashing Connections: sp501e-flashing/sp501e flash.png at main · tonyn0/sp501e-flashing · GitHub
I have a couple of MagicHome controllers as well. Can't say I like them too much. They are better than nothing, but comparing to sp501e they feel a bit underpowered.
