I had legacy (now deprecated) Sonos Integration running without single problem for years. Few days ago I added Piper to HA for 100% TTS avility. Not everything worked right away. So, just in case I tried to migrate to new Sonos Integration. This happens to be a complete disaster. All my current (legacy) integrations and devices were instantly wiped out. New integration found only 2 out f 3 Symphonisk speakers but the devices was not created at all. After few attempts (in between new integration was removed, hub was rebooted with db rebuild, integration readded) I gave up and stopped to install this new Sonos Integration. But since HA has them integrated without any problems and thanks to HADB my new integration is 100% functional and 100% local. So now Speakes + Piper are on HA but all automations are on C8P.
PS. Since I am all set I am not looking for fixing this sonos migration phenomena. This post is to let community know the migration to new Sonos Integration could be very distractive. I hope, this eventually will be fixed.
I was simply using my Sonos speakers to make announcements (so I could tell what and when things were happening on my hub--some using the hub's TTS, others using mp3 sound files). Often, there were announcements, typically several seconds apart, from the same and/or different rules.
Initially, I was lucky if even the very first worked--almost nothing else did. Now, with a few fixes, I'm getting more of those announcements--but it's not reliable. And, the follow-on ones are often jumbled up (old announcements popping out, delays between the speakers involved, etc.).
I'm hoping they look into them and get the remaining issues sorted in the new release. (I have a post about it currently).
I had the same issue, however figured it out. There is not clear what to do after the integration discovers sonos speakers. On the next page click on drop-down list and check them all so the devices will be created.
I had a similar to rob9 use case with old sonos integration. With the new integrator I created preset Group and ,,, the hell broke loose. Wrong speakers, wrong volume, announcements popping out in repeats several minutes after etc, Deleting the Group seems like does not take effect for a long time.
I'm not sure how, but between re-installing the integrator and fiddling with Sonos app my rules are working now like they used to be in old integration, however I didn't test for overlapping announcements yet
