Hi, I search how setup the temperature reading in fahrenheit only for this sensor used for pool temperature reading.
I want all my other temp reading in Celsius and my system setting is set to Celsius but just for this sensor I prefer a fahrenheit reading.
In the device config page there is no option to select F or C.
Someone have idea how I can set it in Fahrenheit?
I suspect that this would need to be done in the driver. If you can find a community driver that works for the device, you might be able to modify it to display Fahrenheit. There are some very good developers in the community, so you may be able to get help if needed.
Thanks @Sebastien I found this wonderful driver and do more than expected!
