I have a rule set to fade 3 lamps over the course of two minutes if a light sensor is triggered. When the action is triggered, however, it ramps all 3 lamps to 100% before beginning the fade. This is annoying when, for example, one lamp is off and the other two are set to 50%. I just want the lamps to fade in place, at their current levels, not reset to 100% and then fade. Is there any way to do this? Thank you.
