Previously I was able to set a fade time and my light would ramp to a set level from OFF. It was possible to do this from the light’s device details page or from RM. Now I’m unable to get the lights to do this. In the device detail page, [Edit] I can go from OFF to 70% with a 30 Fade time, and it works one time. I can also go from 70% to 1% with a 30 fade time and it works, and then I can go from 1% to 70% and seems work consistently, but if I go from OFF to 70% with a 30 Fade a second time, it jumps instead of slowly fading. Seems I can only make it fade one time. This was not the previous behavior prior to the 703 and subsequent 704 updates. Again, this odd behavior continues, even though I have reverted to 702 firmware and restored a 702 database.
I reverted to 702 and restored my 702 database (just to be sure) and it still behaves the same way. Were there some changes that might be affecting the core functionality that can not be reverted, even with a firmware downgrade?
Was there a change to the ZigBee White Color Temperature Bulb driver that would now affect any firmware? Do I need to try removing and re-pairing the bulbs and if so, should I try it first under 702 where I am right now for testing, or should I update to 704 again and then try re-pairing the bulbs?
One of my favorite Hubitat features was fade from off & fade to off, so I hope i can get it back.
